My wife's car developed the habit of wondering across lanes, when the throttle was applied or backed off. Replacing the lower wish bones sorted it. But now 8/9 months later on, the problem is back. And I did get an advisory on the MOT for the nearside lower arm bush. Having re read the Haynes manual it says the bolts MUST be torqued up with the car resting on it wheels.Which I neglected to do last time. My question is. Does the car have to be "insitu" as all four wheels on ground, or can the front wheels be on chocks of wood or ramps. Because otherwise there is no way I'll be able to get to the bolts to do them up without a pit.
kevfromwales
the conrod's REALLY out the block now!
surely if you chocked the car front and rear it would be at the same level as it is when it's on the ground - just get the back up on axle stands and the front up on ramps?
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Mar 29, 2011 11:48:39 GMT
I've even heard rumors about bushes ripping if you tighten them with the car in the air. I've done it myself countless times myself without problems mind you
Mar 29, 2011 15:58:45 GMT
The bushes need to be tightened with the wishbone lifted to avoid them being twisted at normal ride height. You just need to put a jack under the wishbone or hub and lift it to the position it is in when the weight is on the wheels.
If that picture is your wife's car's wishbone you have polybushes with a steel crushtube in the middle. These don't need to be tightened at right height, just greased well. It is only bonded rubber bushes that need to be tightened at ride height
"Alice in Wonderland's Cheshire cat is perhaps the 1.9-litre 205's closest parallel, for like Carroll's fiendish cat, when the Peugeot is gone only the grin remains." -What Car? March 1987
Mar 29, 2011 16:49:45 GMT
Is it a 206 by any chance?
Mar 29, 2011 17:49:31 GMT
it's a mk6 escort. I used some spare rusty steelies I had in the garden, and a trolley jack and blocks of wood on the rear. The rubber bushes were ripped on the removed wish bone. It has knackered the outter edge of a less than a month old tyre. Damn it.
