Olson
Apologies for this thread as I'm sure it's been done to death, but can someone tell me the PCDs of the following please? Mk1 Golf gti, Mk1 Ford Cortina, NSU/Porsche 5 stud. Ta very much, Olson
Screaming 1776cc
SteB
mk1 golf GTi = 4x100 Porka 5 stud = 5x130
Olson
Blimey, that was quick, cheers! ;D
Ford must be 4x108 then?
Screaming 1776cc
SteB
I didnt answer the Ford one because I wasnt sure if very early ones were 4x108 like mk1/2 escorts and fiestas and the like
Olson
Wow, that link is ace, thanks, although some of the VW details look wrong...
Screaming 1776cc
Am I the only one that winces at the damn metrication of 4.25" which is what RWD Fords *really* are
Olson, if you're still after wheels for the Cortina I know someone locally who has loads of old Ford jobbies from his banger racing days (no, not the bent rims off raced cars!).
With regards to 4 stud wheeled fords from the 1960's to mid 1990's which (from my experiance) are all 4x108 (or in the imperial size of 4.25 for our older and patriotic members ) this includes Rwd and Fwd (e.g Anglia 105, Classic, Cortinas, Sierras, Capris, Fiestas, Mk1 & 2 Escort and Fwd 3 &4 Escort). However Beware ... ...of the offset and bore (wheel hub centre size)! e.g. say you may get a wheel off say a Cortina MK1 to stick on a Sierra (or Sierra wheel for the 'Tina) although the PCD stud fitting wil be correct the offset may not and thus the wheel might 'sit' to far in or out (and foul brakes, suspension and so on, or not even fit due to hub flange or wheel up against suspension.). I know from personal experiance this past month that not all Fwd Escort wheels will fit MK3 Fiestas, although both 4X108 the offsets are different depending on style,width and design of alloy wheel.
