Hi guys and gals I'm looking at getting a new set of wheels for the imp, and id like to go for 7" wide rims, now if i fitted 175/65/13's will that be really stretched or not? I only want a little bit! cheers J p.s. i tried using the search function as i know this subject has come up at some point, but every time i ask it to search anything more than 10 days it just spaks out
I think it would be alright J, I've seen 195's on 8 inch rims before which is what I'm going to do on the BMW, it does look well stretched but 175's on 7 inch rims will be 5mm less stretched.
those new rims i got are 7's and have 195'son and i thought they were 205's, 175's should give a bit of stretch, i'd imagine, if thats the look you are going for...
175/50/13's on 7x13's is quite common for Minis, so 65-series should be fine.
sweet! So much stuff for this project, I'm getting excited now! I arrived back from uni today forever, no more education for me The pile of parts to fit to the car is getting bigger and bigger, and ive got less and less time! cheers guys J
Here are my 185 50 Nankangs on 7" rims. £126 for four from mytyres.com. As you can see the rim edge sits proud of the tyre wall so I can't go near curbs but the stretch isn't too much and the bloke who fitted them didn't say a word. Charlie
Last Edit: Jun 1, 2006 22:44:25 GMT by charlie
hmmmm they look spot on, mabe 185's it is then!
J
I've had 185/70's on a 7X13 rim with no problems. 185/60X13 will give you the same rolling radius as the stock 155X12, and they'll go OK on a 7"rim, especially as an Imp's so light.
^ Hot wire That website/chart fingy is GREAT !
Yeah it is, makes sense. useful gadget. my car was lowered on oneside dramatically when i tried those low pro tyres wheels on one side!
^ Hot wire That website/chart fingy is GREAT ! Agreed, just playing with it right now. Shows me that 175/60x14" is spot-on for replacing 145x13" on Starlet (a distinctly unstretched look on 5.5" rim according to the diagram it generates, which suits me fine).
You absolute legend *n
Here are my 185 50 Nankangs on 7" rims. £126 for four from mytyres.com. As you can see the rim edge sits proud of the tyre wall so I can't go near curbs but the stretch isn't too much and the bloke who fitted them didn't say a word. Charlie Charlie - is your car in the readers ride section? It looks really nice Yet another example of the 'Minilite' style wheel looking good IMO Edit; just been playing with that tyre/wheel calculator - its ace! Though its worth noting that different makes of tyres of the same size can give different appearances depending on the tyre wall design.
Last Edit: Jun 2, 2006 10:40:50 GMT by DerbyDan
Thanks hotwire, that really is very helpfull!
The only concern i have now is rubbing, but then again if i go for a bit of stretch then it should be ok?
cheers
J
The only concern i have now is rubbing, but then again if i go for a bit of stretch then it should be ok? Thats why people started stretching in the first place
Edit; just been playing with that tyre/wheel calculator - its ace! Though its worth noting that different makes of tyres of the same size can give different appearances depending on the tyre wall design. Very good point DD. The worst offender I found were India GT's , seemed to have very little tread relative to their width.
