***UPDATED 06/11***
Current circumstances dictate that I need to generate some dollar forbills and other life stuff sorting my fleet so here's a random collection of stuff for your consideration.
Some of this is from my last clearout thread.......
Strut Brace to suit MK1 Astra, brand new £15
MK1 Astra "Hella" grill in usable condition £20
One pair of Rover 3.5 V8 carb heads(and poss a complete set of pushrods), need a good clean but usable. £15pair
Pair of1.75 HS4 SU's with linkages, manifold and airfilter box to suit Triumph Dolomite 1850. Need a clean but should all be there. £20
Three sets of clocks, all vauxhall. Top-Cavalier GSi/Calibra Middle-Nova GTE/GSi Bottom-Astra MK1 1200S.£10each
4-branch exhaust manifold to suit Cavalier/Calibra/Astra fitted with the 2.0XE redtop motor. New, never fitted. £20
A few old head units, all were working when removed. £5each
ATE servo unit, brand new in box. Other than being in a Peugeot/Citroen box I don't know what it fits. Quite slim. £15
Rover K-series ally inlet manifold complete with injectors&throttle body. To suit 1.4&1.6 motors, its two-piece so might be of use to modify for RWD fitment. £15
A pair of new headlamps for a Smartcar, brand new in their boxes. Cant remember which year model they fit but have part numbers so can be checked through main dealer. £60
Some parts to fit Cavalier SRi and GSi.
Fuel computer with selection switch £15
Sunroof motor with cover panel, switch and interior lamp £10
Iluminated sunvisors with a section of loom £5
Fuel filler flap, good condition £5
Pair of electric mirrors, GWO £10
Three pieces of GSi wood trim, usually attached to door cards £5
Pair of new lower arms for Daewoo Nexia but should also fit MK2(and poss MK1) Astra £20pair
Some bits to fit early Jaguar XJ40.
One front indicator/sidelamp unit, not sure which side £5
Pair of rear (fog ) lamp units w/reflectors. one needs a wire reattaching £3each
A pair of doorcard wood trims, poss from a Daimler equiv £5pair
One two-piece bumper mount(front ) £2
Service parts for 3.6-oil and air filters and a set of plugs £15
Pair of Reliant Scimitar 14" 4x114.3 wheels, need a refurb and tyres are bin fodder £20pair
Pair of Defender 90 tubular rocksliders, brand new £35
Pair of BL Maxi / Allegro indicator/sidelamp lens, need a clean and one has slight crazing of the sidelamp part but no cracks £5pair
Austin Maxi LH rear lamp lens, good condition with gasket £7.50
Austin Allegro front Wipac fog lamp assembly, removed from a VDP many years ago for some reason. Good condition £10
Land-Rover Series 2a/3 Clutch Pedal Assembly, never used it myself but looks all good(no cap for master cyl) £15
Land-Rover Series 3 Smiths Heater Motor Assembly, need to test but I expect it will be good. Some rust on casing £10
Land-Rover Series 2a/3 Vacuum Tank, uhh its a metal tank with a single inlet for push-on pipe(suppose you could turn it into a swirl tank) good condition £5
14inch Pancake Filter to suit 2bbl / 4bbl Carburettor, some rust spots but should still polish up nice. measurements will follow shortly £15
B.O.P TH350 Gearbox - Needs rebuilding so I'm led to believe, quite a lot of slop in the tailshaft so might be right. No torque converter or dipstick. £50 WILL BE GOING ON EBLAG VERY SOON
Also, not pictured....
Ford Fiesta MK3 89-94 O/S front wing, brand new aftermarket £10
Willing to take sensible offers, some of the smaller stuff I can post but would prefer pick up(Somerset area) or pony express via Area52 with Bruces permission.
Cheers
Steve
Pair of
Cheers
Steve
