Feb 10, 2011 12:46:09 GMT
here I have a set of 4 13" rostyles complete with trim rings and tyres pcd i'm told is 4" old opel fit
centrebore 48mmas you can see the tyres are off roaders and a little cracking, honestly I would'nt use them on the road but would be happy to use them for off road there is a little rust coming through but nothing serious nothing a refurb would ssort out or just rock em as they are trim rings are kerbed but from what i've seen there is no major chunks priced to go £30 ono will consider delivery pm me for details
Last Edit: Feb 13, 2011 17:39:23 GMT by kauffman
Macoli
Feb 10, 2011 14:42:09 GMT
Do you know whether these are tubeless rims or not? Can you remove the trim ring and post up a piccy of what's underneath?
Wanted: mk2 Cavalier front valence
Steve
Making progress in small, easy to handle chunks of awesome
Feb 10, 2011 17:19:19 GMT
Location please? If these came off an Opel then they are more likely to be 4x100, if off a Vauxhall then 4x4inch
Feb 10, 2011 17:41:16 GMT
They are midget wheels. Tubeless. Have had a spigot ring welded in at the back too.
Feb 10, 2011 18:14:27 GMT
Interested, depending on location!
Feb 10, 2011 23:46:17 GMT
They are midget wheels. Tubeless. Have had a spigot ring welded in at the back too. with this in mind i shall measure the pcd and the diameter of these spigot rings welded in place also get a picture of the trim rings off updates tomorrow cheers for interest guys
Feb 11, 2011 10:03:31 GMT
Pcd will be 4x4" now maybe not as the holes have been drilled out. Midget studs are very small and the wheels centre on the studs, hence the ring being added later for another application.
Feb 11, 2011 10:53:13 GMT
centre bore looks to be 48mm
Feb 11, 2011 13:33:46 GMT
Some Viva/Magnum rostyles had those spigot rings, and a 7/16" diameter stud.
Feb 11, 2011 15:40:49 GMT
Some Viva/Magnum rostyles had those spigot rings, and a 7/16" diameter stud. the person i bought them off had an old vaux but can't remember for the life of me what one it was
B-8-D
down to one car!!
Feb 12, 2011 18:23:17 GMT
pretty sure they are std viva/magnum rostyles.. the spigot ring in the back is factory.. chevette ones had more of a curved face to the "spokes" and didnt have the little pressed inward pointing bit between the spokes..
midget ones I think had more of a recessed section where the nuts sit IIRC...
id be happy to say I'm pretty confident they are viva/old vaux 4" pcd wheels..
si
Last Edit: Feb 12, 2011 18:38:01 GMT by B-8-D
Feb 13, 2011 17:38:20 GMT
thanks for the info guys will amend ! ;D
Feb 13, 2011 18:21:54 GMT
Where abouts are you?
Feb 13, 2011 18:28:32 GMT
near stevenage sg6
Feb 16, 2011 12:35:34 GMT
bump still for sale
psl
Feb 18, 2011 20:15:25 GMT
Deffo Vx rostyles, these are factory 1800 / 2300 magnum fitment
Feb 19, 2011 18:56:02 GMT
the Chevette/Cavalier ones are stamped GM. Easy to tell the difference.
Feb 20, 2011 19:39:02 GMT
bump still available !
Feb 28, 2011 10:37:24 GMT
tttttt
Violet Vivid
Reports of my demise were somewhat exaggerated
Feb 28, 2011 12:33:28 GMT
£20?
and collect them tongiht?
xXx
Violet, purple-loving Landy obsessed Purple-haired CyberPunk Almost model & occasional word wrangler regarding Landies xXxIf she can't decide on what kind of genitalia she likes to play with you're better off without her. Move on... play with Land-Rovers.
