May 24, 2006 13:07:51 GMT
yep tyres, nowt dodgy Had a look on kwik fit site (first one that came up) cos some of mine are a bit worn. the new set ive got, the front two are quite healthy but its the inside edge thats worn down below 1mm. Obviously been on a lowered car, however i have seen worse. I'd say they ate safe as the rest of the tyre has about 3mm. Are they legal though? kwikfit: I'll get a piccie at 5 if noone can advise on text alone. cheers
May 24, 2006 13:09:03 GMT
hold on the pic helps a bit I might be in the clear then, its here now if anyone else wondered..
bstardchild
Club RR Member Number: 71
Legal limit - tyresbstardchild
@bstardchild
Club Retro Rides Member 71
May 24, 2006 13:23:45 GMT
It can also depend on if there are wear bars the the outer grooves - if no then the breadth of the tyre is reduced further
Legal limit - tyresBenzBoy
@benzboy
May 24, 2006 13:25:53 GMT
I always thought that as long as 75% of the tread was legal then you're fine. Obviously if it's worn down to the plys it's not though...
May 24, 2006 13:30:38 GMT
I told a policeman about the 75% thing once, I was right except it had to have "visible" tread on the remaining 25% and I didnt, He gave me a vehicle defect notice.
May 24, 2006 13:33:53 GMT
sounds borderline, i'll get some pics up at 5. It should take me upto MOT then thy'll make their minds up, false economy though as a second test isn't cheap! luckily its the same garage doing the tyres... some obvious examples on the KF site www.kwik-fit.com/changing-tyres-illustrations.asplowered cars are an expensive business!
May 24, 2006 16:47:20 GMT
To be honest if its getting down to that kind of level and its your daily driver I would change them anyway. Not that I am one to judge as I was using tyres like this on Sunday ;D
May 24, 2006 17:12:15 GMT
legal I'm 1.6mm over the middle 3/4. mot is the same or 1.6mm over the middle bit if its got raised tread. all iirc.
May 24, 2006 18:41:05 GMT
Later than expected due to a dopey mishap! and The inner edges are probably less than 1mm but look at the big rain channels theres loads of depth, defo safe IMO but probably illeagal!
bstardchild
@bstardchild
May 24, 2006 19:43:53 GMT
Legal IMHO - but I'd be changing them fairly soon
May 24, 2006 20:03:56 GMT
Yeah thats what i'm thinking, thanks. I'll leave them 2 till MOT time in August save a few £'s for other stuff.
May 24, 2006 21:09:05 GMT
if you crash with f*cked tyres insurnace can go out the window.
May 24, 2006 22:13:03 GMT
Considered that too. Damn cars. expense! they do look safe though as water can travel through center sections but steering in water could be not so good though. might see what the tyre man says... 'definately need 4 lad'! 'Doh!'
May 24, 2006 22:21:05 GMT
personally i wouldnt worry about that. check out my front camber wear. yes, lowered cars are an expensive business.
May 24, 2006 22:39:03 GMT
why doesn't someone invent lowered car tyres? such a waste weaing one side only. Idea: a higher outside sidewall, or a rounded bike tyre approach. hang about, that copyrighting right there!
I'm off to my drawing board...
bstardchild
@bstardchild
May 24, 2006 23:12:05 GMT
why doesn't someone invent lowered car tyres? such a waste weaing one side only. Idea: a higher outside sidewall, or a rounded bike tyre approach. hang about, that copyrighting right there! I'm off to my drawing board... Alternatively correct your camber once lowered
May 24, 2006 23:32:28 GMT
Good point, but for the crazy-ass camber look i think i've got a market! and my next major lowering project has a live axle. yay!
