May 23, 2006 14:59:15 GMT
I think I'm going to remove the rear swage line (rear arches back) on the scirocco to try and even things up a bit after spraying the sides black.
The question is: Is it likely that the paint work will remain ok when I take it off? I've heard that the paint can sometimes come off with the strip - if this is the case I'll leave it in place.
Swage line removalarthurbrown
@GUEST
May 23, 2006 15:01:53 GMT
Are we talking about a plastic trim strip or a defined groove in the metal work - the latter is what I would define 'swage line'... If it's placca trim, how is it fixed on? with tags or glue? Either which way it shoudn't be too hard to get off or damage the paint if you are careful.
May 23, 2006 15:03:25 GMT
swage line is usually stamped into the metal panel.
May 23, 2006 15:25:59 GMT
It's just the rubber strip I'm on about......I pressume it's just stuck on, as I've seen other Scirocco's with it removed - I suppose the best thing to do is try it! Cheers
@GUEST
May 23, 2006 15:49:42 GMT
Hair dryer and pull it off slowly. Bit of petrol to run off the residue, job's a good 'un
filmidget
East Midlands
Mostly Lurking
May 23, 2006 16:00:23 GMT
Never done it myself but general opinion is they usually come off pretty easily. Don't throw them away though (can't get them new, and nobody seems to save them off scrap cars...)
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
May 23, 2006 18:32:30 GMT
mine had them removed, not even noticeable in the paint and mars red usually fades like a fooker.
May 23, 2006 18:50:41 GMT
Its a rubbing strip, Dear Boy, a rubbing strip. Swage lines are creases in the metal, usually to give strength to otherwise large(read flimsy) panels.
