thesam
Jan 25, 2011 18:39:59 GMT
Anyone have some contacts of people they use around the Bristol area for this?
Have a growing number of part now that require some treatment..
I have had a chat with the guy Bruce (MysteryMachine) has used in the past for powder coating, but he does not do shot blasting and I would rather my parts were done before taking them to him for the PC.
Hewp me pweeez
thanking you
Hi Sam, I have a large sand blaster down at the unit. I'll be calling you tomorrow about other things anyway so can give you more info and maybe even a quick demo if you're able to pop over still?
As for powder coating, I'll tell you more tomorrow although it sounds like I gave you my contact even though I don't remeber doing so (old age I guess LOL)
purplevanman
Way too orangey for crows
Jan 26, 2011 10:39:22 GMT
try and find somewhere that does both as rusty steel that has been blasted will rust extremely quickly, better still, blast, then take it to a platers, acid dip and zinc it, then PC it Bruce will help there as well IIRC
Welder, fabricator, general resto work
Jan 26, 2011 10:54:19 GMT
Oh yes....I have a good contact that can do the acid dipping and zinc plating too. See you later Sam
I know this is an old thread but just to let u guys know, i have always used Keynsham Industrial Coatings. I use them for my shotblasting and coating. I've always had good service from them. They are not far from the Co-operative supermarke.
Nov 27, 2011 16:28:24 GMT
Yeh, just want to second the above entry by lobster-man! Keynsham industrial coatings; now renamed - Keynsham Powder Coatings are always reliable and value for money
;D
Brian Damaged
West Midlands
Club RR Member Number: 33
Nov 27, 2011 17:01:29 GMT
If you're a bit closer to the West Midlands I'll happily recommend www.qualityblasting.com/ in Lye, Stourbridge. We use them at work, quality friendly service.
Nov 27, 2011 17:16:27 GMT
Just also to add to the mix, Sticklepath Forge, just outside Ilminster in Somerset(about an hour from Bristol).This is what I do, shot blasting and powder coating.Can blast small bits, to vehicles(can get a truck body in our blast room), and also have a very large oven!Pm for any details needed. ;D
