Excuse one or two attempts at "arty" angles, but not that easy to get a good shot in the garage.
This is how I spent today...
First coat goes on the door shuts and frames.
First coat on the bonnet.
And the second...
And the boot....
I think this is two coats on the whole car....
I've used Lechler Ti Green on it, which I found kinda like spraying porridge. Mind you my first attempt at spraying 2 pack and I'm not sure I got the gun set to the right pressure, and the first coat mix was a little iffy. PLus the fact its not just a regular high build primer its a sort of primer-come-stopper-thing. But on the whole its on and its covered, even if it has the texture of artex in a few places, I'll get that rubbed down OK.
So I have officially joined the late 20th century at least as far as paint application goes
And the second...
And the boot....
