weeeell then I tried to do some stuff in the garage today and proceeded to spend most of the day clearing stuff away and falling over other stuff so why not try to exchange for some well needed beer tokens.
All stuff collected from Camborne in Cornwall although I'm regularly in Bristol and even bits of London so try me.
Will swap for 14" tyres. Ideally 195/45 or similar. Will also take Marlboro Reds and Carlsberg instead of cash
4 VW P-slots, Polished face, 14x6 ET38 With 185/60/14 tyres with plenty of tread on em. More piccies if you want them. £130 collected. Provisionally Sold
Set of Rover SD1/P6 alloys. 14x6. Tyres on 'em are 195/60. Just for refernece tho 'cos they're really old and probably shot. £100 ish
3 look really good, one has been painted black at some point and 1 seems to be corroded. I have 2 metal centre caps and 20 odd chrome nuts too ;D
May be able to re-finish if required. Just ask.
Next some Chromey hub capsx4. Ford I think. Dunno why I have em
£tenner - ish?
Spax Adjustable Front Shocks. For Polo's Mk1 - 3. all good no leaks etc. I've never used them as the thread at the top is different to standard and I couldn't be to find other nuts. £50 ish Provisionally sold
Full set of Eibach springs for the old polo's mk1-3. 40mm drop. (i'd rather be lower and less comfy . unused £100-ish
Lever cover for (i think) polo mk1-3. Front seat £5 posted
Copper coloured vinyl. Single piece. Approx 1.4mx 1.1m
£10er
Cyclone Wheel centre caps. Approx 150mm dia at base 70mm dia at top and approx 75mm tall. £8. Sold!
Set of 8 manifold studs. Deffo not 8mm as I needed. I think they are imperial 1/4 inch. One end very course thread. Sorry I don't have a thread measurerererer. 50mm total length.
£4 posted.
Quick release positive battery terminal C/W by pass line to attached to stereo or alarm system. Will only fit battery terminal upto approx 15mmin dia. £5er posted.
4 BMW centre badges. Thin metal 65mm overall dia. 1 has a couple of scratchs and one is not completely flat but will prob flatten out with some gentle persuasion. £5 posted - SOLD
4 plastic manifold spacers/seals.60mm approx shortest side dia 45mm internal dia. 72mm centre to centre for fixings. £8 posted
Bow shackle. 6.5t (no lifting cert though) 150mm overall top to toe. 25mm dia on pin and opening 37mm at choke point. £10 posted
Magnetic orange warning lamp. Magentic to stick on the roof. Works off the ciger lighter. All good £15 posted.
Wheel nuts from old rovers 17 in total. Bit of surface rust but nothing too bad. £15 posted (heavy)
2 hella spot lamps. these were from a mk2/3 polo front grill. Quite rare appently. Good nick but do have a reg number etched onto them unfortunately. £20 quids.
Then at the end of the day of hard work why not relax with Deluxe Massage Cushion Or buy it for the missus ;D
£15
£tenner - ish?
£10er
£4 posted.
£15
