May 18, 2006 22:20:41 GMT
Well ive spent the last couple of days at uni on a lathe taking chunks out of my billet blower pulley! Its dropped from 1500g down to 450g, a bit less inertia! Ive had plenty of trouble with it acting like a bell and vibrating, unfortunatly it left chatter marks from the tool on a few of the surfaces So the next task is to take a few finishing cuts with a fresh tool. Here are some pictures of the pulley Before - And now - So i still have plenty to do, the other pulley needs to be machined to fit the crank pulley, then theres the intake manifold, injection, fuel system, and front radiator. Lots and lots to do, and not much time before CARS J
Last Edit: May 18, 2006 22:22:51 GMT by Blown_Imp
May 18, 2006 22:24:02 GMT
Impressive, is annodising still in fashion?
I never know when to stop on a lathe.
bstardchild
Club RR Member Number: 71
May 18, 2006 23:24:06 GMT
Very impressive indeed
Note for reanimation "when you are taking chunks out of the chuck you have gone to far"
bryn
May 18, 2006 23:33:47 GMT
Impressive as ever, will be good to see the finished article.
street
6.2 ft/lbs of talk
Terrific, looks like your putting alot of thought into your project, nicely engineered Keep us updated with more pics!
Good work! Keep at it, can't wait to see this finished Impressive, is annodising still in fashion? I was reading about DIY anodizing a while back. Tub of battery acid, some food colouring and a bit of electrickery... sorted! If that's your thing.
May 19, 2006 11:22:51 GMT
home anodizing sounds like fun, i may have to try this on a scrap bit of ally.
Those chatter marks have really p[issed me off, I'm not too sure how to fix it either. I don't really want to take any more off of the the front face, and make it too thin, balls!
J
May 19, 2006 12:27:48 GMT
home anodizing sounds like fun, i may have to try this on a scrap bit of ally. Those chatter marks have really p[issed me off, I'm not too sure how to fix it either. I don't really want to take any more off of the the front face, and make it too thin, balls! J Plasticine packed in the back (it changes the natural frequency, preventing the excitement)and a small skim off the front face ;D HTH Dom
slater
Club RR Member Number: 78
May 19, 2006 13:21:17 GMT
don't worry about the chatter marks. Id just use some emery/wet'n'dry/scotchbrite etc and polish it up.. If you attempt anodising you have to have mirror finish on it so better get started!
May 19, 2006 14:45:57 GMT
dom, you legend, thats some good logic!
I shall try that next time i go in, i think ill use bluetack as i have some of that already.
I thought you could anodise onto a machined finish, I'm sure the seat posts i used to make at USE were anodised on to machined. Only the suspension ones though, the rigid ones were polished then anodised.
cheers
J
Mr K
May 19, 2006 14:48:40 GMT
looks sweet. forgot to ask my brother about my lazer cutting last night, will ask him tomo if i remember. wonder how my pulley is.... the problem with getting things made for free by the bored night shift man!
May 19, 2006 14:57:24 GMT
its all good, plenty of time! I'm trying to get as much sorted now as i can, the really attack it when i get home!
J
