Hi Chaps. I am upgrading my daily driver so need this gone. It's Black, has 158K on the clock and has Tax and MOT until the end of April.
It requires some bits doing to it:
Service.
O/S cv joint knocks around corners.
Alt belt has come off, may need new tensioner.
Knocking top mount.
Headlight wiring.
Bonnet hinge.
The paint is pretty knackered but never fussed me, being a work horse, also the drivers seat has a hole in the bolster.
It has had the front and rear upgraded to phase 2 spec, however the headlights are wired into the sidelights because phase 2's have separate bulbs for hi/lo. Someone who knows how to wire in a relay could fix this easily.
Also recently changed both front ball joints and fitted a reconditioned P/S pump. It might even have a bit of Derv in it too.
The car will start and drive but no alternator belt so heavy steering and no electrics.
Thanks for looking.
Harry.
07966092882.
Service.
Knocking top mount.
Headlight wiring.
Bonnet hinge.
Thanks for looking.
Harry.
07966092882.
