gingernik
'65 Beetle 1200
May 18, 2006 11:25:06 GMT
As this is Retro Rides, I'm guessing a fair few of you know your stuff when it comes to carbs. Perhaps you could shed some light on something for me. My Polo has developed a weird problem, it's been going on all winter where the revs will drop at idle to about 500rpm (I think it's supposed to be at 800-900). I've been sitting at the lights sometimes and they'll just drop, or it'll settle lower when I come to a stop. Also, when it's cold out, the engine doesn't tick over smoothly, it kind of 'chugs', if that makes any sense. It's got a Pierburg 2E3 carb on there, and I know I should really get a webber, but I can't afford it at the moment. cheers in advance! ;D
Stu
May 18, 2006 11:48:21 GMT
Not too sure on Pierburg carbs but when my old Polo (solex carb) had similar symptoms I cured it by unscrewing the main jet, draining the float chamber and blowing out the main jet with an airline (foot pump ). After that I ran some redex through it whilst revving the car quite hard once it'd warmed up and all was well. Do you have a Haynes manual for it? That should show you how to clean out the carb. I assume the fuel filter is ok, it's not run really low on fuel and picked up cr@p in the bottom of the tank etc etc?
May 18, 2006 11:52:19 GMT
Take the pierburg off and throw it as hard as you possibly can. Either that or clean it as above / replace it with a good known secondhand one if you don't know your way around one. Give it a good servicing and check the ignition components (dizzy, HT leads, etc) as well if it's a while since it's had one, then you know you're off to a good start.
Second hand Webers turn up on the bay a lot. What engine is it?
May 18, 2006 11:54:55 GMT
Oh and camera shops sell cans of compressed air if you haven't got a strong foot pump (football adaptors work well if you have)
gingernik
'65 Beetle 1200
May 18, 2006 12:02:01 GMT
Take the pierburg off and throw it as hard as you possibly can. Either that or clean it as above / replace it with a good known secondhand one if you don't know your way around one. Give it a good servicing and check the ignition components (dizzy, HT leads, etc) as well if it's a while since it's had one, then you know you're off to a good start. Second hand Webers turn up on the bay a lot. What engine is it? It's a 1.3 monster! Same as the coupe S Not too sure on Pierburg carbs but when my old Polo (solex carb) had similar symptoms I cured it by unscrewing the main jet, draining the float chamber and blowing out the main jet with an airline (foot pump ). After that I ran some redex through it whilst revving the car quite hard once it'd warmed up and all was well. Do you have a Haynes manual for it? That should show you how to clean out the carb. I assume the fuel filter is ok, it's not run really low on fuel and picked up cr@p in the bottom of the tank etc etc? Yeah, got a Haynes manual...somewhere. It's dropped quite low a couple of times (usually right before pay day!) so that might be it. I'll have a go at giving it a clean once I get my exams done and move back home.
May 18, 2006 12:08:12 GMT
Don't bank on a Weber being the solution to your problem either - I replaced my Pierburg 2E2 with a Weber and I still get a curse word idle occassionally!
Could this be fuel pump related? Does this idle issue appear when it's not cold (weather)?
gingernik
'65 Beetle 1200
May 18, 2006 12:12:18 GMT
Don't bank on a Weber being the solution to your problem either - I replaced my Pierburg 2E2 with a Weber and I still get a curse word idle occassionally! Could this be fuel pump related? Does this idle issue appear when it's not cold (weather)? It does sometimes, not as frequently though. You reckon it could be the fuel pump then?
May 18, 2006 12:24:20 GMT
Don't bank on a Weber being the solution to your problem either - I replaced my Pierburg 2E2 with a Weber and I still get a curse word idle occassionally! Could this be fuel pump related? Does this idle issue appear when it's not cold (weather)? It does sometimes, not as frequently though. You reckon it could be the fuel pump then? I suppose it could be a starvation issue, but this would have an effect when driving at revs not just at idle! It could also be the gasket between carb and manifold - if it's dodge then there could be too much air getting in to the mixture..... First port of call as stated above is to check the fuel line / filter and give the carb a clean.
