Right, for newbies and those who aren't up to speed, my current project is the installation of a 2.2 16v subaru legacy engine, in the rear of my lovely "ratty" VW T3/T25 caravelle (1983, wasserboxer) Right, off at the weekend to sunny Stoke On Trent to visit a Mr Richard Jones of RJES. I've put some money in his account to pay for my bellhousing and crossmember, I just hope the crossmember is going to fit around my exhaust. ;D, otherwise I've gotta hack it up . Ordered a new stock clutch today from Ebay, for a bargain £99 delivered, I'll not use the center, as I'll be using the Volkwagen center disc. So now I just need some new fuel line, the rubber engine mounts, a starter motor (I can probably rob the starter and mounts from the donor legacy 2.0 I bought), a few clips, and some coolant line and I'm about set. Once I've done this conversion, I think I'll have a crack at a 2.0 legacy powered beetle.
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
You're making this sound too bloody easy!
This is my engine, installed in the rear of the previous owners car. He's gone for a turbo engine. Meaning he can't fit this either, shame
You're making this sound too bloody easy! Spending the money has been the hardest part so far, but I figured, once I've got the bits, I can do the other work. Also, it's easier to "copy" something else (i.e. the loom) than it is to learn from a fresh. There is a method to my madness.
qwerty
Club RR Member Number: 52
Conversion progressqwerty
@qwerty
Club Retro Rides Member 52
How easy is actually phsically fitting the engine? Is it a case of all new engine mount's loads of grinding and welding? So could you (if you so desired fit a twin turbo legacy motor? That would be roooooode. Twin turbo legacy engined t25 pick up. Slammed with some 19" chrome wheels and satin black paint ;D
May 16, 2006 10:42:38 GMT
Cool! I think I'm going to have a go at this on my van when I can afford the bell housing and cross member
May 16, 2006 10:44:34 GMT
it's in principal, very easy with the correct parts, the engine mounts will be RJES ones, so "bolt on" pretty much.
I've tried to make this as bolt together as possible, as I want it to "look" factory.
the turbo uses a pull, as opose to push clutch, but the flywheels are all the same.
RJES does a turbo bellhousing, but if I do decide to later turbo, I'll use an uprated N/A clutch on a turbo engine.
If you use an adaptor plate, you can just use uprated VW clutches.
May 16, 2006 11:57:53 GMT
been shopping at 'Chateau Big Al' there then
May 16, 2006 12:01:45 GMT
been shopping at 'Chateau Big Al' there then Yeah , he's a nice bloke actually. Of course I knocked a few £££ off the asking price for everything I got from him, there was no WAY I was gonna pay VZi prices .
May 16, 2006 12:17:55 GMT
Al is a top bloke....
May 16, 2006 12:51:10 GMT
Next..... 2L Turbo impreza engine? Or gearbox upgrade? Adam
May 16, 2006 13:12:57 GMT
Next..... 2L Turbo impreza engine? Or gearbox upgrade? Adam Box I rekon, then maybe more power, T25's at speed can be sketchy so I'll see how the 2.2 is 1st. That said, a turbo is to go fast, and going fast shouldn't really be in van, so that may happen to a beetle
qwerty
@qwerty
May 16, 2006 13:15:08 GMT
Of course fast should be in a van! Because no one expects it! How much power has the 2.2 got? Do you think MPG will be improved. Its just our t25 only gets about 20-22mpg.
May 16, 2006 13:33:20 GMT
Of course fast should be in a van! Because no one expects it! How much power has the 2.2 got? Do you think MPG will be improved. Its just our t25 only gets about 20-22mpg. Yes, fast is good in a van, but the 2.2 should be fast enough..... for now I'll see about 30mpg, and a reliable torquey 140bhp, so I'm told. One of the main reasons I wanted this conversion, was I'm sick of the pee poor fuel return of the wasserboxer, but I do tend to drive at a fair rate, and always thrashing the poor thing to get at . Subaru 2.2's are the best all round engine for power/economy, and i can LPG it too ;D
May 16, 2006 13:38:42 GMT
There's a twin turbo legacy that I'm not, repeat not bidding on on ebay at the moment. I'm definately not bidding on it as I already have too much on my plate with everyone else's cars and vans and my own Beetle project. Plus my van still needs another £200 ish spending on it just to make it roadworthy with the curse word DG in it.
How logical am I? My willpower knows no bounds ;D
May 16, 2006 13:40:27 GMT
Mart, just do it, with a subaru conversion, it'll be fit and forget, provided the cam belts are done pre-install.
qwerty
@qwerty
May 16, 2006 13:45:19 GMT
I'd be intersested to see photo's of the conversion etc.
May 16, 2006 13:45:38 GMT
I'm going to get it through it's test first. I am. I just keep telling myself that ;D
I've got a 1300 screamer planned for my Polo as well - your "so many ideas, so little money" tag seems slightly appropriate at the moment ;D
May 16, 2006 13:46:11 GMT
Aye, well once I've sorted the camera I'll be doing plenty of images.
qwerty
@qwerty
May 16, 2006 13:48:45 GMT
Sweet. Looking forward to browsing through them becoming more and more inspired!
