Mate, top work! Your eyebrows look worse than mine did! (Filler up to 1/2" thick in places, ran a magnet over it had to go 3" back into the wing to get it to find metal...) Nice one.
Some superb welding there. Quite a lot of that rot and the previous bodging looks all too familier. I would keep it FWD personally there not bad engines if you make sure the oil ways are clear and servive em regularly. Id say more reliable than a slant. Of course theres a huge argument in the TDC over whether slants or OHVs are better ;D
namless
Club RR Member Number: 26
cheer guys ;D Colonelk - does the job, your welder needs it too its quite heavy lol nickbrad - kool mate some more updates are planned. xbo11ox - yea i think its actualy easier workign with that stuff also it holds the shape quite well compared to cheepo thin stuff. elmotheewokking - its a proper design flaw with these old cars plenty of places where the rubish from the wheel sits and hold water endsup eating the untreated metal. pauldaf44 - naa I'm not going to be changing the engine its staying stock, i can say for a 1500 its proper nippy. however i still need to do the headgasket on it not mixing water/oil or loosing compression but just leakign alittle bit on the side.
Showed this to my dad he said "He clearly knows what he is doing!" .. high praise indeed .. looking great, keep up the good work!
namless
Showed this to my dad he said "He clearly knows what he is doing!" .. high praise indeed .. looking great, keep up the good work! cheers David that means a lot to me mega mojo boost
purplevanman
Way too orangey for crows
Ouch!!! you're putting nearly as much steel in this as I did!! Looking good though, should last a while now keep up the good work
Welder, fabricator, general resto work
namless
yea al i think after this lot of steel and waxoil it should see it a another 40 years haha
Waw, I wish i could weld like that, i would have taken one look at that wing and run a mile.
RetroMat
Column Shifting!
that looks familiar! you;ve just given me a huge mojo boost! I've have this looking at me every time I go in the garage for the last 3months got round to doing the inner headlamp surround at the weekend, will have pull my finger out and get it finished now ;D
Last Edit: Jan 5, 2011 19:41:26 GMT by RetroMat
namless
good evening everybody... ;D its time for part 2 the nearside which seems to involve bit more then the offside. cheers for the comments guys ;D who likes photos put your hands up.. now now we have a few for today started this side by bracing the edge of the light brow by spotting a sheet to hold it in shape then cut out the shape for the inner light mount cut a slimmer strip to make the edge tacked all nice and tidy and stitch welded it good penetration me thinks cut the rotten one out and stuck the new one in place fits about right i had kept the edge of the light brow so i can maintain the shape of the inner light mount, and keep size within the limit. chopped the whole lot off copied the shape from the off side and reversed it cut it out on sheet metal and started tacking it together then made the the top and sided of the new wing the reason i make it in two pieces is to get the sharp edge on the top and its easier to stretch and shrink in to shape. not the easiest curves Tbh looks about right finished that off and took the whole lot out to make the inner light surround apologies as i am missing some pictures I can't seem to find them, but here is the finished light surround primed in some rust primer then caped the whole lot back together and painstakingly seamed it together trying not to warp it i know it looks like pigeon poop but hey its the penetration that counts i had done this lot from underneath and then the good old flapwheel comes out looks about right 8-)next update we will be lookign at this culprit till next time goodnite, hope you enjoyed this session of Weldathon ;D
purplevanman
easy bit next still looking good m8
namless
yea pretty straight forward its got straight lines
Ooft. Now that looks good. Also a pretty hand visual reference for when I get to crack on with it. Cheers! I admit, I cheated with mine and bought some fibreglass wings off e-bay (£50 the pair, bargain), but the inners are, err, not there.
Impressive work!
1953 Austin A40 Somerset 1959 Austin A35 1958 Austin A55 Cambridge 1975 Vauxhall FE 2300S 1985 Austin Maestro 1.3 Base
cheer guys ;D pauldaf44 - naa I'm not going to be changing the engine its staying stock, I can say for a 1500 its proper nippy. however I still need to do the headgasket on it not mixing water/oil or loosing compression but just leakign alittle bit on the side. Thats a common fault with these engines. The oil way is on the back right of the block looking from the front. When you replace the HG smear some gasket sealant around the oil way hole, otherwise it will start leaking again in no time at all.
HIGHLY IMPRESSIVE WORKS, 18/10
namless
elmotheewokking - glad the pictures will be of some help the fibre glass does make work a hell lot easier I had thought about that also grunty had mentioned them when I went to pick up the car, but I like making noise haha angrydicky, xbo11ox - thanks for the comments guys ;D pauldaf44 yea that's the exact spot its leaking from bloody oil way. noted thanks for the tip il make sure I glue it back together properly
Seth
What they said, nice work stitching this together
DutyFreeSaviour
very very impressive metal magicking going on.... hat is well and truell doffed to you sir.
John
Quality metalworking Just a thought - when I did something similar to a Sprint many years ago (I cheated and used some not rusty wings though!), afterwards I put an extra plate in that blanked off that whole mud-trap area at the front. Was just tacked and seam sealed. That was in 1990 and the car is still about. You might also be able to find some plastic arch liners off something more modern and adapt them. Will last so much better then Keep up the good work - wonder if you could get a Saab 99 lump in there.... Nick
