Ive never understood why mgb's are so popular, they're not quick, they don't handle that well and they're not particularly pretty.
Tends to be old duffers driving them though, so maybe its something that only appeals to people with bladder weakness and erectile disfunction ;-)
XK lumps were big old iron block things, they must weigh a ton! Really pretty car though, many wants!
Koos
Yeah I tire quickly of all the articles that pop up in classic mags on mgs. Oh we'll. Back to classy Vivas now :-).. Sooooo.... the latest on the rattle is that its much better but still there since we loaded a new ignition map onto ECU late this afternoon. On friday I used the timing light at work (mines broke with a blown bulb I cant seem to locate), locked the timing at 10 and checked the timing marks. It was at 12 degrees so I adjusted the 'trigger wheel offset degrees from 50 to 47.5 till the timing light showed 10. Pretty chuffed I had got the trigger wheel so close by eye I created a new map using a generator online just to get a better starting point. It immediately away looked so much better than the previous table- which was the default ignition map that came with the code from Extraefi and was possibly a map for a rover V8 which the fella at Extraefi owns. Anyway we took it out for a good drive and re-tuned the whole VE table to suit the new ignition curves. But the gearbox rattle is still present and although I have to purposely try a bit harder to get it to rattle I feel that either I have rattled the box enough that it now needs some love, Or the gearbox was already a bit tired and as previously mentioned by a mate it is now become noticable because of the lower spread of torque from the Piston V6, Or its still there because of my possible crazy unmatched driveshaft yoke angles..which I sort of forgot to check last week, Or I could retard the ignition even further? Hannah has already dropped the numbers in the bins where the rattling is present by a further 3.5 degrees. We have learned so much more about tuning even in the last hour of driving it and playing with the numbers. A little afraid to keep dropping them but will keep experimenting I think. Overall the car is even better to drive!!! Much smoother about town without the sudden snappyness that the last ignition table with its massive early advance seemed to create. I'm loving this tuning stuff and seeing such dramatic changes. Here is the latest map. The generator made the 750 rpm line all 10s for some reason? Not sure what I should do with that? I totally understand that the table aint perfect. Its a simply generated, pretty linear table created from quite basic info. I also realise that we will never get if perfect until we use a dyno. But its getting better and we are learning :-) The lines that Hannah knocked back are the 1200 and 1700. The rattle seems to be around the 42~72Kpa x 1200~2000rpm area. I took a small data log but not sure how to share it. Or even read it.. yet another whole area of more learning!
Welcome back to Vivadom. I have much to tell you so please sit down with a cup of tea and read on. The new balljoint has so far been behaving well. Along with the balljoints I had shipped over from the motherland were some new front upper arm bushes. The ones on the car were most likely the originals and they were buggered. So two weekends ago Hannah and I spent the day at work and doted on the little Viva. While I set up the new plenum chamber lid in the mill Hannah removed the upper arms from the car. Because these bushes can often be quite tricky to remove Hannah machined up some pressing cups that locate properly inside the edge of the bushes and another that locates neatly against the arms. With these the bushes pushed out square and the new ones pressed in easily. You can see how stuffed the old bushes were- two of them were not even bonded into the outer sleeve anymore and free to wobble about. Hannah and her new favourite toy... Big vice makes it easy.. (sadly no press at work but luckily they were not as tight as we feared) The old knackered bushes.. I also continued on with machining my new idle air control valve that I had started making the night before. Its to replace the existing iac which was very noisy because I attached it to the underside of the plenum chamber. The iac i have been using is the original Mazda item stripped out from its home which was cast into the throttle body. Because its a pulse width modulated type it vibrates as the solenoid bit switches on and off really quickly. Not a problem in a solid casting but noisy when mounted to a boom box of a manifold. Old one near its location bolted under the plenum chamber.. new pipe for hose to remote iac.. So my new one is remotely mounted down near the fuel line. It still makes its sound but is no where near as noisy. Luckily its only active during warmup. Now I could have just bought a Bosch iac or similar but I like making these sorts of little items. More fun. Plus I have loads of throttle bodies with these iacs as spares. Another thing that I should have done ages ago was fit my new Mazda thermostat! The engine never ever got up to proper working temp. I had fitted a brand new Tridon brand thermostat but once pulled out and tested against the new Mazda item it showed me why I was so cool running. The Tridon one would open quicker and stay open till 77 degrees against the Mazda one that would shut bang on 82. I have heard bad things since fitting the tridon one about them. The Mazda one is so much more nicely made. Results? yeah! The engine runs much hotter, gets to temp quicker and does not yo yo up and down. I have also discovered since replacing it that I had set in the wrong resistance value for the the temp sensor and hence the tuning adout. I have not found a definite answer yet but I think these engines run around 95 degrees. Onto the new plenum chamber lid. I have been meaning to build this for ages after having discovered that the old 4mm thick lid flexes in and out loads from the engine suck. It also created a strong reverberation at certain revs that boomed through the car. Dave (avengertiger) sourced me a piece of 6mm alloy and I finally set to work. I wanted raised ribs this time so milled the outside edges down with the old 6 toothed milling head that is missing 5 teeth.... thwack thwack thwack.... Last friday night I stayed in and carefully and slowly (no feed or coolant on our old mill) milled out the ribs while listening to Jim Mora. On Monday it got coated with some wrinkle paint, which took ages to go off due to the cold. When the paint was cured I scrapped it off the raised ribs... Then fitted it on Tuesday when back at work. Its so much quieter and I think looks much better :-)
Last Edit: Apr 24, 2016 20:57:07 GMT by yoeddynz
Steve
Making progress in small, easy to handle chunks of awesome
Sept 1, 2013 10:08:58 GMT
Engine bay is looking well tidy mate Loving all the custom work with regard to the plenum chamber
Sept 1, 2013 10:20:50 GMT
Holy cow, I am lost for w-
Sept 1, 2013 10:36:25 GMT
Lost for wurthers originals?
goldnrust
West Midlands
Minimalist
Sept 1, 2013 11:17:39 GMT
Niiiiiiiiiiiiiiice I'm loving how clutter free the engine bay looks!
Sept 1, 2013 19:36:08 GMT
Looks like i could eat my Wurthers originals off that engine!
Koos
Sept 1, 2013 20:01:30 GMT
You certainly could.
Steve- there is still too much clutter. I want to tidy up the heater hose area at the back. Maybe tig together some neat hard lines. But for now I'm happy.
I put up some photos of the car from this weekends trip south to the oldschool meet. Was awesome and on way back we managed 40 mpg! That with having some very fast fun driving over the hills too.
Sept 1, 2013 22:00:35 GMT
I read that the NHS spends something like ÂŁ250m a year on antidepressants. My idea is that they should just send depressed people to sit in a deckchair for a few hours and look at the sheer excellence of this car perhaps with some nice scenery in the background. Maybe acute cases of depression could get taken for a spin in it. It cannot fail to make folk feel better about themselves and the world in general.
Sept 1, 2013 22:01:07 GMT
Last Edit: Apr 28, 2016 19:37:22 GMT by yoeddynz
Sept 1, 2013 22:16:09 GMT
Just for Mr plums I am going to add another couple of photos from trip to support his theory on pretty pictures helping out depressed people :-) on the way back from Hanmer over the Lewis pass..
Last Edit: Apr 28, 2016 19:50:37 GMT by yoeddynz
Sept 1, 2013 23:42:11 GMT
I think the theory is bust looking at that beautiful scenery just made me wish I could visit NZ. But going for a road trip definitely does lift ones spirit.
Ah man, now I feel depressed about the unending dullness of my entire life, scratch that theory its nonsense
Seth
All simply wonderful as always.
Hi Alex,
I missed the Old School Gathering by a week. I was in Hanmer Mountain biking the weekend before after a week down South for Business. Loads more Snow than the week before. Is that the Rainbow Station Road. Awesome country!!
The Heralds on hold as I'm to busy and funds are low anyway. Your engine bay is sublime my friend. Have you started building the 2.5 engine yet or have I missed that part. Keep up the good work. I'd love to check out the Viva next time I'm down your way.
69 Herald 13/60 with Turbo 1600 MX5 engine, Lexus 5 link rear end, 17in wheels,300mm ventilated disc's and subaru 4 pot calipers
Sept 2, 2013 20:05:48 GMT
Dat scenery! :-D
Koos
Sept 2, 2013 22:28:29 GMT
Hello mr Frankenstein. Yeah the weekend was good- shame your dates were out. Great mtbing there though so that would have been nice.
I need to pull finger and start rebuilding a 2.5. Must order a gasket set from the states as so much cheaper there.
Sept 2, 2013 22:37:38 GMT
Just want to thank you for posting those photos mate the scenery brought back a lot of memories Glad the Viva went well, is the box behaving its self now?
Sept 2, 2013 22:40:09 GMT
Cheers. Nah the box is still noisy. I drive around it but will drop it out in next few weeks and open it up. Really does sound like backlash from worn thrust bearings. Must also check those drive shaft angles too. Simple jobs I keep putting off.
