Nov 24, 2010 14:44:05 GMT
Hey
I'm changing the cat over on my car because the current cat has a little 'rattle' to it? What is it thats rattling? And would it be worth less to a scraper now that it does rattle?
Its on an E36 320i
Cheers
Current retro - 1996 Alfa Romeo GTV / Daily - 2016 Nissan Qashqai Previous retros - Prelude, Integra, XR2s, XR3s, Orions, CRXs, Sylvia S12, S13, Pulsar, ZX 16v, 205 Gti, MX5, MR2 etc
Copey
Nov 24, 2010 14:50:40 GMT
rattle means its broken mate
Nov 24, 2010 14:53:01 GMT
Yeah I guess something is broke. I wonder what/how? For scrap it should be worth the same though right?
Nov 24, 2010 14:54:34 GMT
normally on the e36/46 the aly cover breaks and then causes a rattle as it hits the cat, not that the cat failed.
Nov 24, 2010 14:59:54 GMT
ive now taken it of the car/ away from the ally cover/heat shield the rattle is coming from inside the cat. sounds like there is 1 small metal piece loose inside?
Nov 24, 2010 15:02:11 GMT
Ahh rite, it's broked then. Take it down the scrappers and keep quiet
Nov 24, 2010 15:04:56 GMT
thats what i hoped! but you can hear that something broke inside whilst handling the cat... Its all there for scraping, unsure how it can be worth less?
Nov 24, 2010 19:34:32 GMT
Hey I'm changing the cat over on my car because the current cat has a little 'rattle' to it? What is it thats rattling? And would it be worth less to a scraper now that it does rattle? Its on an E36 320i Cheers the rattle is the inners of the cat broken away from the caseing.. 9 times out of 10 what happens is it then rattle around in there, till it rounded of all the edges! so it looks like a ball!! and then just rattles around in there even more!!!! I bet I change a couple a mouth for the same reason! scrap man should still give you same price for it mind.. as the inners is what they want.. and after all.. its still in there.. just "rattling" around a bit ;D
Last Edit: Nov 24, 2010 19:36:21 GMT by petetong
Nov 24, 2010 19:38:42 GMT
I took the exhaust system off the MGF today and found the cat was rattling. You can put your hand in and move the grid thing inside. They're not too expensive on ebay.
Nov 24, 2010 19:42:39 GMT
a rattling cat is worth much less than a non rattler.
Cat converter with a rattle?ChasR
@chasr
Club Retro Rides Member 170
Nov 24, 2010 23:10:05 GMT
Indeed.
I'd look for a good genuine cat off ebay off a Beemer getting broken for spares etc.
have a picture.
