very cool indeed!
Ive made oen of these out of a 45 gallon drum with a 4" wagon exhaust as a chimney yet it just seems to smoke and gets nowhere.... there is a door and also breathers in the bottom any ideas :-( ive given up on it I'm thinking maybe its too big?
will
I've been busy collecting bits for one of these. Just 'found' a nice chimney at the side of the road, a nicely shaped bollard from a posh part of town. I'll be keeping a eye on this for ideas, liking the oven you've built in.
Have done some more fitted hinge to bottom door for air in, ash out then fitted hinge to oven and cut an old trolley up for the mesh that's got to be welded then made another baffle and a rod so it can spin put it all together in chimney an then put a handle on the ash/air door with three settings 1: closed 2: open a little 3:open full then i made a ash removing tool(got to be cut smaller an welded) and found a lever for the baffle
hi all finished the handle on the oven and the shelf in the oven welded the grate in place and welded the ash scraper just got fire it up to burn the paint off and paint it black hopefully i have finished fabricating this wood burner
all finished
Perfect for this time of year, and any other times you want a bit of heat in the place.
can we have a pic of it going now, be nice to see the finale of all your hard work
blythy
no grate for the wood to sit on/ash to fall through? does it burn well like that?
we used rover k series headbolts to make a grate 6" from the bottom and had the door a bit higher,it gets so hot the bottle gets a cherry glow!! it does eat through wood though,a dustbin full every 4 hours or so
stefan
If it isn't broken fix it till it is
Wood burns better with out a grate, you need a grate to burn coal.
Metromon you barrel is to big for the size of flue you would need 6" minimun on a burning chamber that big as well as a throat plate to speed gas entry speeds to the flue, it will also make it give out more heat, you also need to make sure you have enought air going in to service a burning barrel that size (plenty of flame not just a charcoal burn with the doors shut)
Twizzle I like the idea of the oven in the top thats some good thinking
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
right got it out of the garage and sat it in the garden an lite it put loads more wood on an it slowly got hot opened the oven door then found a plastic cap left it for 1 min and it came out like this kept it running for an hour with it on tick over smoke slowly coming out of chimney all paint almost burnt off this is how it looked with the lights turned off that's it finished just waiting for maxlee so i can drop it off at c-unit know i will have to make a smaller one!!!!
nice one, I'm gonna get one of these made pronto for my lockup
ace, cheers for the night pic, looks cool
joda
what are the legalities of fitting these in both commercial and domestic properties?
with them being home made in the eyes of an insurance company, if your garage was to burn down would you be covered?
Has anyone looked up the Building Regulations regarding these?
maxlee's wood burnerretrowagen1234
@GUEST
Thats brilliant.... I wanna get stuck into making one soon... Not sure what way to go with it tho... Either just simple and effective. Or all over the top and steampunky
stefan
Dec 10, 2010 21:54:12 GMT
You are not alowed to fit a wood burner of any kind in a domestic garage under the building regs so if it burns down then no insurance cover.
Domestic property you would have to tell the insurance company.
You are not allowed under building regs to fit a none E marked stove in a domestic property so again no insurance cover, you also need building control or a HETAS certificate from an installer to comply with building regs and insurance
That said I have one in my garage.
maxlee
Dec 14, 2010 16:27:15 GMT
how rude am I didn't even see this topic till now! thanks again mate looks even better in real life and the oven is just class we are yet to fit a chimly etc as we are having a few problems getting some duckting cheap/free. might do a side line of warm food as it might pay better then the cars do lol p.s the zimmer might be on its wheels by the end of to night so next time u pop down we might have some space and progress
Last Edit: Dec 14, 2010 16:29:07 GMT by maxlee
