I have long been interested in the BMW K100 head swap for the A series motors, but I think it woud actually be a better fit on a Fiat 850 block. Similar bore sizes, similar sized blocks and most importantly the fiat block has no water pump on the front so there is no need to extend the cams and run a belt. The BMW cam chains could likely be used with minor mods.
Anyway....before I go out and drop some coin on BMW parts I might not be able to use I am trying to do some research. My blocks have 65mm bores so I am thinking of the 8 valve K100 head as that is what is used on similar bore A series. My google-fu is apparently weak and I cannot find the bore spacing of a K100 motor so I turn to you, oh knowledgeable retro-riders in hopes to find the bore spacing on the A series motors that use pistons in the 65mm range.
This has been on my mind for a year and a half or so but I could never think of a suitable and inexpensive way to deal with the cam timing on a counter-clockwise rotation of a Fiat 850 motor, Well today I sealed the deal on a 1958 fiat 600. It will be delivered in two weeks and the 600 transmissions work with clockwise rotating motors, so this plan is back in planning.
Some 600's for your trouble
