Nov 17, 2010 10:50:25 GMT
I have Googled, Ebay'd and dug around a bit, maybe not the right keywords. I am looking for about an inch wide black marker pen , the type used by scrotes to tag trains and tubes. I need it/them to do borders on my Retro flavoured home made wall hanging, to seperate out the different stories. Can anyone help before the mods find and move or kill the thread please ?? LINK HERE: www.retrorides.proboards.com/index.cgi?board=othrmod&action=display&thread=92190&page=1Thanks. Rian
Last Edit: Nov 17, 2010 10:52:02 GMT by grizz
Nov 17, 2010 11:04:06 GMT
Hi Rian,
Nice wall. (Never thought I'd be saying that about a wall!!)
Might not be waht you want, but another option/solution would be insulating tape. With a marker pen you'll run the risk of wobbly lines unless using a straight edge....which you then run the risk of ink bleed under the edge etc....
With insulating tape you can take your time, reapply (as long as it's not pressed down hard) and get perfect edges every time. Rub it down once done then apply some heat from your Nicola's haridryer to get it to bond better to the paper. Job done. No hassle, no stress and no mess.
Nov 17, 2010 11:11:02 GMT
Hi Rian, Nice wall. (Never thought I'd be saying that about a wall!!) Might not be waht you want, but another option/solution would be insulating tape. With a marker pen you'll run the risk of wobbly lines unless using a straight edge....which you then run the risk of ink bleed under the edge etc.... With insulating tape you can take your time, reapply (as long as it's not pressed down hard) and get perfect edges every time. Rub it down once done then apply some heat from your Nicola's haridryer to get it to bond better to the paper. Job done. No hassle, no stress and no mess. You are spot on Bruce, the insulation tape was and is plan B, as I have a load of rolls, and in different colours, as one gets in bulk packs, however, I had thought the imperfection of a freehand drawn frame would look more authentic, but you have me thinking now, as it may be better done very neatly, and only in black. Hairdryer.... erm, not one in this house, but I do have 2 electric paint stripping guns.
Nov 17, 2010 11:19:48 GMT
task
Nov 17, 2010 11:34:14 GMT
I bought them from a shop just off Oxford St in London for my cousin last time, can't remember the name of it which isn't much use!
I'll send him a message and see if he can remember!
Nov 17, 2010 12:01:48 GMT
i believe ive seen some hobbycraft shops but i would of thought most art shops would do something - though they will be rediculously overpriced
2001 Micra 998 - Daily
1986 Mini Mayfair 998 - Former Daily - Garaged
Nov 17, 2010 12:05:06 GMT
hobby craft have the chalkboard pens use see signs done with in pubs etc btw that is a cool wall
Nov 17, 2010 12:32:28 GMT
They're in Hobbycraft. Just move it quickly, you'll get a straight line.
task
Nov 17, 2010 13:00:40 GMT
Nov 17, 2010 17:41:48 GMT
last time i went in staples they done a 1" thick marker pen if thats any use?
Nov 17, 2010 18:29:42 GMT
yorkshire junkies is a good site to ask, a lad off there did a piece for my boys bedroom/playroom a few years back
Nov 18, 2010 18:29:37 GMT
graphotism . com bit pricey these days but will have what you need.
