marsie
Nov 12, 2010 20:27:11 GMT
Hi all,after a dabble with the XJS i got an offer i couldnt refuse and did a deal with a 1971 triumph herald 13/60. As you would expect from a 40 year old,its a bit tired.The body is rough up close and the engine is tired but both will be getting sorted in the near future Paul ;D
Some people are like slinkies? They serve no real purpose in life but make you smile if you push them down the stairs!
1972 Scimitar GTe se5a
Nov 12, 2010 20:53:49 GMT
Nice, I do like a Herald.
Looks pretty clean!
Whats your plan for it?
Koos
marsie
Nov 13, 2010 14:10:03 GMT
it looks clean in the pics but up close there is more filler than steel.It is having an engine/box swap as well as modding the rear axle and smartening the bodywork
stevea
Nov 13, 2010 16:12:03 GMT
Looks alright that does, is your rear axle mod going to be a swing spring conversion?
marsie
Nov 13, 2010 17:27:02 GMT
Its already got the swing spring setup but i am looking at ways of beefing it up to take something like a sierra diff and some sort of wishbone setup so the wheels don't tuck under so easy? don't know how yet though???
stevea
Nov 13, 2010 19:12:41 GMT
The standard diff will take a fair bit of abuse before it falls to pieces, the Spitfire 3.63 ratio is said to be one of the strongest. I think Ray? has helped prove this with his rotary engined Herald, I am also aware of a V8 engined Spitfire with a standard diff. The tuck under problem really isn't as bad as some make out, like many people I had done many thousands of miles in a Triumph with a swing spring and never had any problems. There are a number of racers out there also who have used swing spring, though a few have converted to a CV version of the rotoflex drive system as used on some the Vitesse and GT6 cars. Here's the setup used on my GT6
marsie
Nov 13, 2010 20:11:32 GMT
I have thought of using a gt6 type rear end(with bottom wishbone).Just because i cant get my head round the fact that the halfshaft IS the wish bone,it just doesnt seem safe .Maybe will stick with the standard diff and worry about it if and when it goes bang? The engine that is coming out And the one that will be going in ;D Paul ;D
I have thought of using a gt6 type rear end(with bottom wishbone).Just because I cant get my head round the fact that the halfshaft IS the wish bone,it just doesnt seem safe . Millions of Beetles can't be wrong! Although I must say that I much prefer the strength of the Beetle universal joints to the Triumph's rubber doughnuts.
Nov 14, 2010 21:11:36 GMT
Hi Paul,
Looking good, Wish my herald was in half as good nick. Sump line on the vauxhall lump looks good for going in the herald. I've stuck with the swing spring and 1500 spitfire diff. It does work....but everything needs to be in good condition. I spoke to a vittesse racer at Canley classics who was really really helpful.
1987 Mini with Suzuki Swift GTI engine 2005 BMW E91 320D Touring
marsie
Nov 14, 2010 21:39:26 GMT
Thanks Alex,don't be decieved by the photos.It is nowhere near as nice in the flesh as it looks in the pictures.It has had a rough skim over with filler and a crappy paintjob Good to see a few heralds on here undergoing various conversions .Will be interesting to see them all finished Paul
