Apr 29, 2006 21:42:21 GMT
Did you use the Piazza prop ? and did the centre bearing bolt up to the Torque tube front mounting points ? Been looking underneath my Donor, got the prop off and nearly got the axle off now as well. Did you use the bolt on upper link brackets and links as well Cheers Dom
Apr 29, 2006 22:05:40 GMT
used all of the axle mounts but only the ends of the prop was a bit pushed for time on the prop so welded a new tube in but it realy could do with new uj's and balencing . only other big job i've got is to make up a proper exhaust the one it has at the mo is made from old bits and bobs plus the back box is a chav realy
Some more pics of the next stage ;D 4 Link components and Chassis mount Engine mounts Turns out my 6-point cage has turned up at work as well ;D ;D Feels like its coming together now ;D
wow those turrets are neat. Did you buy em or did someone make them specially for you?
wow those turrets are neat. Did you buy em or did someone make them specially for you? They are Group 4 Round Escort Turrets "Modified" by Gary at Retro Motorsports to be Rounder to suit the Chevette/Kadett Knock out Panels He also added the Strut brace Mountings while he was fitting them This is what they look like from below ;D not being used yet but will be with the Piazza Axle soon ;D They will tie in to the Cage as well as I`ll modify the rear stays to pickup on the Turrets and add a double rear Diagonal that way I know all the loads from running coilovers will be fed into the cage ;D
sterling work! looks super neat.
