Apr 29, 2006 12:52:36 GMT
Thought Id give you an Update ;D Not finished but well on the way, Final mountings next and Chargecooler/Inlet manifold ;D Belt run is close to standard as well with near 180 deg wrap on the charger The Pully size needs increasing to slow the charger down ;D Get some more pics up later Cheers Dom
Last Edit: Apr 29, 2006 12:54:43 GMT by CR500Dom
street
6.2 ft/lbs of talk
Apr 29, 2006 12:56:03 GMT
Looking very neat Dom, loke its supposed to be there! Good work!
Apr 29, 2006 13:07:38 GMT
Woo! Loving that! ;D
Cannae wait to see it goin'!
racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
Apr 29, 2006 13:45:34 GMT
KERWALITY ONO1111ONE1111ONEONEONE111 - its going to whine louder than my girlfriend (well mabe not)
Apr 29, 2006 13:48:55 GMT
KERWALITY ONO1111ONE1111ONEONEONE111 - its going to whine louder than my girlfriend (well mabe not) I tell you what ........ Stick up an Audio file , I`ll do the same when its running and we`ll see which ones louder ;D ;D I susect mine`ll be louder but I bet yours sounds nicer ;D
Apr 29, 2006 13:52:51 GMT
Nice one Any idea how it is for space in the engine bay. How will the engine be mounted are you using the standard zetec mount positions or you mounting it on the sides. I don't think I have looked under the bonnet of a fwd car with one of those engines do they sit straight or on a slant.
Apr 29, 2006 14:01:20 GMT
Nice one Any idea how it is for space in the engine bay. How will the engine be mounted are you using the standard zetec mount positions or you mounting it on the sides. I don't think I have looked under the bonnet of a fwd car with one of those engines do they sit straight or on a slant. It`ll be tight but it will fit Engine will be side mounted, but mounted Via World cup type bushes to the Chassis legs rather than the Crossmember I may need to reshape the crossmember slightly to clear the sump, not sure yet untill I get it in place I hope not but Chassis mounting the engine seemed like by far the best option In the donor it sits like this: Its going on a new bellhousing to a Type9 box ;D
Last Edit: Apr 29, 2006 14:02:19 GMT by CR500Dom
Apr 29, 2006 14:41:31 GMT
I will have loads of questions for this installation I am sure.
Is the charger sitting where the power steering used to be. If so how, much horse power does that kind of charger take to run at full load. That looks like a sprung tensioner, is that strong enough to stop the belt from slipping on the charger.
Might sound like daft questions but its really just for a few things I am considering for the future.
Apr 29, 2006 14:54:03 GMT
This is looking quite exciting Dom, I'm watching VERY carefully lol
Apr 29, 2006 15:08:38 GMT
I will have loads of questions for this installation I am sure. Is the charger sitting where the power steering used to be. If so how, much horse power does that kind of charger take to run at full load. That looks like a sprung tensioner, is that strong enough to stop the belt from slipping on the charger. Might sound like daft questions but its really just for a few things I am considering for the future. It is roughly in the same place as the power steering pump used to be, its a Cooper S Eaton M45 and on this I`ll be running it around 10,500 rpm which is right in its Maximum efficiency zone, I have the graphs at work but from memory its about 12hp at those revs. Tesioners are fine normally, we ran one on a Jag V6 with a single 6rib FEAD belt and an M62 charger, that had Pas, AC, Alternator, waterpump, supercharger etc all run from a single belt, we did run 65lb belt tension on that one though Its more about getting the wrap than anything ;D Are you thinking of doing the same thing then ? Do you want some Brackets making at the same time ?
Apr 29, 2006 18:57:55 GMT
a blown zetec........i like ;D
Apr 29, 2006 19:01:10 GMT
I will have loads of questions for this installation I am sure. Is the charger sitting where the power steering used to be. If so how, much horse power does that kind of charger take to run at full load. That looks like a sprung tensioner, is that strong enough to stop the belt from slipping on the charger. Might sound like daft questions but its really just for a few things I am considering for the future. It is roughly in the same place as the power steering pump used to be, its a Cooper S Eaton M45 and on this I`ll be running it around 10,500 rpm which is right in its Maximum efficiency zone, I have the graphs at work but from memory its about 12hp at those revs. Tesioners are fine normally, we ran one on a Jag V6 with a single 6rib FEAD belt and an M62 charger, that had Pas, AC, Alternator, waterpump, supercharger etc all run from a single belt, we did run 65lb belt tension on that one though Its more about getting the wrap than anything ;D Are you thinking of doing the same thing then ? Do you want some Brackets making at the same time ? Its more for a project I am thinking well in the future I have about another six I need to start/ complete first. Always like to do the groundwork well in advance though
Apr 29, 2006 19:10:52 GMT
a blown zetec........i like ;D Zetec SE Big difference ;D In weight and sophistication ;D This one with Charger and charge cooler will be lighter than a Naked Zetec But cheers ......Would fly in a Fester ;D
Apr 29, 2006 20:37:14 GMT
looks good dom are you going up the half way hous tomorrow heres another blown one a normal zetec though this one , in jo's new HA viva
Apr 29, 2006 20:53:26 GMT
a blown zetec........i like ;D Zetec SE Big difference ;D In weight and sophistication ;D This one with Charger and charge cooler will be lighter than a Naked Zetec But cheers ......Would fly in a Fester ;D exactly what i was thinking, when ever you mention an engine transplant for a mk1......its zetec, but I'm not that keen but hummmm
Apr 29, 2006 21:09:35 GMT
looks good dom are you going up the half way hous tomorrow heres another blown one a normal zetec though this one , in jo's new HA viva Whats happening up there then ? Is there a Battlesbridge on this weekend ?
Apr 29, 2006 21:21:53 GMT
its the turbosport meet thought you where there last month was thinking of raking the kadett if the weather is ok ;D
Last Edit: Apr 29, 2006 21:22:10 GMT by Deleted
Apr 29, 2006 21:29:26 GMT
its the turbosport meet thought you where there last month was thinking of raking the kadett if the weather is ok ;D Turbosport is next weekend, 7th of April not sure why they moved it but they have Is there anything else going on ? Hows the Turbo going ? ;D
Apr 29, 2006 21:33:50 GMT
ahh good job i asked then ;D it going alright i'm taking the prop to br done on tuesday so should put an end to some vibrations got a few little jobs to do on it other than that it goes well should have all the bits for the engine in the van by next week i'll get a sound clip of it once its up and running ;D ;D
Last Edit: Apr 29, 2006 21:35:57 GMT by Deleted
