Apr 28, 2006 22:21:12 GMT
well my fiesta was once blue and i wanted it matt black but it turned out with more shine than i wanted, would a rattle can job peel off after a few months though, don't have a propper sprayer and compressor now oh and best place to buy matt black in a rattle can ? might do a tester on the bonnet
Apr 28, 2006 22:54:43 GMT
It shouldnt peel off provided you key up the old paint first. I'm no paint man but i'd say go over it with some 360 first. It took me about 10 half litre cans to get one almost decent coat on the cortina, so seeing as your cars black already and about half the size 10 should be about right.
Halfords or any motor factors will have satin black in stock. Just be prepard to have a very stiff finger for a few days ;D.
Apr 28, 2006 23:18:33 GMT
good point, might do a panel at a time or each panel in a slightly different black
Apr 29, 2006 10:17:17 GMT
find local unipart or partco
600 ml cans coupla quid
wayyyy cheaper than halfords
Partco Autoparts Ltd 152, Abbey Lane, Leicester, Leicestershire LE4 0DA Tel: 0116 261 0770 Classification: Motor Factors
2001 HONDA CT110 (NOT RCV)
Apr 29, 2006 10:47:20 GMT
poundland sell satin black ;D youd wanna key it with something a bit less abrasive than 360, try a 600 or an 800. we used to prep shells with 1200 at the bodyshop i worked at, but for a ratty satin job itd be easier to key with soemthing lower. or use scotch cloth . if you have access to the spraying tools itd be a lot cheaper to buy some propaaa paint - i paid £25 for 2.5l metalic strato silver and ive still got about a litre left, itd be pennies for some matt paint
Apr 29, 2006 12:48:08 GMT
yog the money on a decent set of rims instead.
Apr 29, 2006 15:12:35 GMT
got rims sitting downstairs with 4 brand new tires, in need of bolts
and yeh id rather do it with a compressor but don't have one anylonger
Apr 29, 2006 19:36:30 GMT
Why not just gently flat it back with 1500 & 2000 W&D. Should give a nice matt finish, assuming you didn;t spray it enamel.
Apr 29, 2006 20:55:55 GMT
on the tin it said "semi-gloss machinery black" thats what you get when you ask your mother to buy the paint
Now in my usual "helpful" fashion I'd say thats either an enamel base or acrylic paint. Best thing to do is try an inconspicuous spot first and gently give it a go with some 1500 grit wet & dry (used wet and soapy). If it matts off to a nice suedy finish its acrylic and it it goes white and scratchy or doesn't sand back at all its enamel.
If its enamel you need to apply a barcoat before spraying with celly or 1K really.
