binboy
Hi ive just destroyed the gearbox in my 1989 Scirocco Scala 1.8i. The linkage is worn and I hit 1st instead of 3rd, I think the box was on its way out anyway. Ive seen some Scirocco gearboxes on eBay but there miles away.There is still some Golfs MK2s and loads of mk3s in a great scrapyard that I use. Golf boxes look the same but I don,t want to spend time removing one to find out that it don,t fit. Has anyone ever put a Golf box in a Scirocco? Thanks Neil
Slammed 1975 Mercedes 240d back with Dez 1978 W123 Mercedes in yellow 1972 Danbury delux VW camper 1967 Aussie import split screen camper Sold Slammed 1992 Golf 1.8 1987 Bmw 320i sold 1984 Mitsubishi L300
RobinJI
In a word yes. As long as it's off an 8v 'big block'. So that's any of the 8v engines which lean backwards in the bay.
I stuck a late mk2 golf engine and box into my Scirocco. Fitted easily. Just keep the Scirocco linkage, mounts and other bits, and it should go on easily enough. In fact the gear box code was exactly the same on the golf one as the original Scirocco one.
I believe a 16V one will fit, but you'll need to swap the clutch too as the in-put shaft is a different size.
I'm not too clued up on mk3's, so can't say for sure with them, I know they did some later/higher spec ones with hydraulic clutch's and cable shift in some of them, which would not fit, but I'm not sure on the earlier ones.
dubzi
If the linkage is worn, replace that otherwise you'll have the same problem with the new box. You can get a kit for £30 or so.
Happiness ain't at the end of the road. Happiness is the road.
What they said - do the complete kit and you'll be amazed at the transformation. Wierdly all Mk2 Roccos have a strange curved path across the gate but that's natural.
also make sure u get ones with the right size flanges for the drive shafts ther either 90 or 100mm ones.
binboy
Hi thanks for all your help, I'm going 2 pull the box out next weekend, do you know were I can get a linkage kit from?
RobinJI
also make sure u get ones with the right size flanges for the drive shafts ther either 90 or 100mm ones. Ah yeah, forgot about that. Although you can swap these over from your old box if you end up with the wrong ones. There's a cir-clip which needs removing, then they just pop out. Although my 88 Scala had the 100mm flanges which match up to a mk2 golf box anyway, so I'd imagine yours will be the same. I'm not sure about the linkage, although GSF are always the first place to try for that sort of thing. I had a TSR stainless linkage on mine which was nice. This one
Last Edit: Nov 7, 2010 20:21:46 GMT by RobinJI
binboy
Hi them TSR linkages look good at £40, Il phone the scrapyard I use tomorrow and see if they have any 1.6 or 1.8 MK2s in. I'm not sure about MK3 boxes I know that most have clutch cables but not sure about the linkage. Thanks
