hi all
I'm quite new but thought id get some pic's of my car up
it's a 1990 mini city. however it does have a mid mounted GSXR 1000 lump and box driving the rear wheels via a chain to the diff. Means no reverse but its quite quick for a mini.
I haven't had it that long. also i didn't build it as i don't have the time or patience too although there still a fair bit of fetleing and setting up to be done.
so the spec is as follow's
Z car's front and rear subframe/roll cage
2 cobra buckets and 4 points
Willwood 4 pot front callipers and disc's with KAD biasing box's with ford rear disc's
Digi dash 2 with shift lights and gear indicator
7x13 superlite's
carbon bonnet and front end with carbon boot lid
coil over's all round
steering lock limiter
wide arch pack
re located fuel tank to the front
plexy windows
top speed around 125mph
0-60 around 4 sec's
weight 590kg
mpg around 25 to 30 or a lot less ;D
unfortunately I am no wizard with the camera so will have to make do with the last owners pic's till i sort that out
7x13 superlite's
wide arch pack
plexy windows
0-60 around 4 sec's
weight 590kg
