Apr 25, 2006 11:56:20 GMT
I picked up a can of alloy wheel paint the other day. It was 6 quid for a can. Which supposedly will do 5 wheels.
First off, is it going to look any good? I mean, 6 quid, its hardly expensive is it, anyone else do this before?
Now, i have sprayed from rattle cans before, but it was onto plastic skirts, I'm going to apply in a # pattern over the wheel, left to right and right to left, then up and down, down and up.
I have some wet and dry paper, so i presume the better i Key the original surface the better it will take, and the smoother the finish will be?
The bloke at the shop said not to bother with laquer? Is he talking from the lower end of his body, and if so, is there a special laquer to use?
Apr 25, 2006 12:04:18 GMT
Good question. I'm faced with this too. now wanting to spend a wad load i got in contact with a friend of a friend who is sand blasting them, plan is to spray em with the tin of £8 paint i bought but i'm pondering undercoating them to take the pitting out a bit or just laquer over the blasted naked surface. I nearly wish i'd bought one of those TSW yoko packages now, spending more than the car on these old 15's!
Apr 25, 2006 12:06:22 GMT
I painted a set recently... admittedly it was balck rather than silver finish, but I used the same technique as you described & it worked nicely. I did however put a couple of coats of laquer over the top at the end as some added protection
Spraying Alloys - DIY??BenzBoy
@benzboy
Club Retro Rides Member 7
Apr 25, 2006 12:10:20 GMT
I painted mine with ordinary car paint - primer, then topcoat, then laquer. I used laquer mainly to protect the polished rim and stop it oxidising. They need doing again now though, but this was 2 years ago.
Apr 25, 2006 12:15:03 GMT
powder coating gets mentioned a lot but that sounds like more expense. my crusade for an inch bigger wheels seems nearly poinless now and i've messed up a few times, so having a sandblaster attack 'em gets my frustrations out and rid of some of the oxdised patches/craters!
Apr 25, 2006 12:20:54 GMT
I'm going to paint the wheels on my new Mk2 GTI black.... as I'm not a fan of Hockenheim's really, but can't be fished to get different rims, and reckon they'd look better in black on a silver car...
Last Edit: Apr 25, 2006 12:21:06 GMT by rainking
Apr 25, 2006 12:43:25 GMT
I painted a set of Mk1 Goof 9 spokes in spephel alloy wheel paint a couple of years back and they looked ace, just like when they were new. They were properly shagged before as well. Prep is the key I think
Apr 25, 2006 12:48:28 GMT
I painted a set of Mk1 Goof 9 spokes in spephel alloy wheel paint a couple of years back and they looked ace, just like when they were new. They were properly shagged before as well. Prep is the key I think fancy prepping 4 TSW Hock's?!? ;D I'm lazy!
Apr 25, 2006 13:18:05 GMT
It took chuffin ages!! I may have got at least 3 Mk2 Goof 8 valve steelies spare soon as the Scirocco is shortly departing - you'd only need to bother the scrap man for one more...
Apr 25, 2006 13:33:02 GMT
I was once thinking about spraying my G40 alloys black. then i figured that on BBA RA's, you'll need to spend at least four years per rim prepping. to make matters worse they were 13"s, so smaller holes.
they stayed silver.
Apr 25, 2006 13:44:17 GMT
Hmm.. this is as I feared...
I may well be punting the Hocks on via Ebay then and acquiring a set of G60 Steelies....
Apr 25, 2006 13:49:13 GMT
My Azev's are just painted in smoothrite I think!
That's all I was going to do to re-paint the huge scrape down one of the "arms" from where I whacked something I shouldn't have!
Last Edit: Apr 25, 2006 13:49:52 GMT by prophet
Apr 25, 2006 13:49:42 GMT
Hmm...
Apr 25, 2006 14:23:08 GMT
Hmm.. this is as I feared... I may well be punting the Hocks on via Ebay then and acquiring a set of G60 Steelies.... FTW!
Apr 25, 2006 14:29:27 GMT
Hmm.. this is as I feared... I may well be punting the Hocks on via Ebay then and acquiring a set of G60 Steelies.... FTW! this was my initial plan... but I was trying to reduce costs....
Apr 25, 2006 14:35:35 GMT
My brother has a set of lame assed TSW Blade imitations with a pair of 15" newish Avons on and a pair of non-descript legal tyres that'd suit a set of G60 wheels - could save a few bob, do you want me to ask if he wants to sell them? Or are you thinking of going for new ones?
Apr 25, 2006 14:38:01 GMT
Cheers matt, will probably buy new tyres.. got a couple of sets of wheels to sell, and a few other bits.. so should make enough money back....
I'm just being a bit tight! ha ha!
slater
Club RR Member Number: 78
Spraying Alloys - DIY??slater
@slater
Club Retro Rides Member 78
Apr 25, 2006 16:58:54 GMT
Hammerite Smoooth FTW! Brush it on and it looks just as good as powder coating.
philly
Apr 25, 2006 19:45:33 GMT
i do this all the time as its a good money earner:- spayed a set of pug 106gti alloys black on sunday and did the whole job in 5 hours which included prep, primer, top coat and lacquer! also did some vtr wheels the weekend before- bought for 50, painted and sold to a barry for 170!!!!!!! just no ask me to do any alpinas!
spaceframe mini project, bmw 635csi, mx5
Apr 27, 2006 16:07:49 GMT
mrsigmas goofs pslots were painted with hammerite smooth, hours before lastyears retro show, they were still tacky when fitted... lol
2006 Audi A3 2003 Fusion 2 looking for a project....
