Apr 23, 2006 12:37:55 GMT
There's a set of Revolution 4 spokes on eBay at the moment - but they're a different PCD. A friend linked them to me, saying that the PCD is only 1/16th of an inch different - but in my mind that's 1.5875 millimeters too much difference and it wouldn't be safe/usable. Anyone had experience with this? cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4633401025These are the wheels
Last Edit: Apr 23, 2006 12:43:04 GMT by Lewis
Apr 23, 2006 12:56:52 GMT
Some will say it's fine.
Others will say it's certain death.
I say give it a go, take it for a rag up & down somewhere with lots of space around you.... if it feels like they are wobbly or might make a bid for freedom, take them off and put the idea to bed...
Apr 23, 2006 12:58:14 GMT
Damned comedians ;D
Ta Pogweasel. I'll think about it.
Apr 23, 2006 13:12:18 GMT
There's no way using 4" pcd wheels on a 3.75" will work. There's debate about the 100mm/4" pcd wheels being interchangeable, with a lot of evidence saying they're not, but Midget wheels on a Dolomite isn't even worth debating - it's a no-go I'm afraid.
Apr 23, 2006 13:14:20 GMT
Good, that's not a problem - like I thought it wouldn't be sensible anyway. Thanks very much!
slater
Club RR Member Number: 78
Apr 23, 2006 13:15:31 GMT
I think you may get away with it!
If you can get them to fit they will be safe as revolutions use a straight shank type nut as oppose to a tapered seat. Whether they will fit depends on how much clearance there is beween the shank of the nut and the hole in the wheel. If theres over 0.75mm clearance on each nut then in theory they should fit!
If there isnt enough clearance they you could enlarge the holes in the wheels slightly or even turn a bit off the shank of the bolt!
Whatever happens it should be as safe as any wheel that uses straight shanked nuts.
slater
Apr 23, 2006 13:17:37 GMT
so its 1/4" differance not 1/16th then?
Apr 23, 2006 13:20:21 GMT
If it is 1/4in different I retract my above statement. Ain't no way that's gonna go
Telkman
Nurturing Malevolence
Apr 23, 2006 13:21:40 GMT
A friend linked them to me... Yes, remind me never to link you to thinks I intend to bid on again... In my mind that's 1.5875 millimeters too much difference and it wouldn't be safe/usable. As opposed to the 1/16" difference I mentioned?
Apr 23, 2006 13:21:48 GMT
Yea a 1/4's bonkers! I don't know what the PCD of a Spridget is so can't say for sure and I'm off down the pub for lunch now ;D Whehey! WE got you here in the end! You best post up your car now!
Last Edit: Apr 23, 2006 13:22:20 GMT by Lewis
Apr 23, 2006 13:24:13 GMT
don't DO IT!!!!!!
Studs are designed to stretch longways (along the length) If you use the wrong pcd, you are applying stress sideways (across the diameter) and the studs WILL sheer. I was that soldier.
Telkman
Apr 23, 2006 13:25:30 GMT
Ah, Midgets are 4" PCD? Memory is obviously failing, as I thought they were 3 13/16"!
slater
Apr 23, 2006 13:34:02 GMT
don't DO IT!!!!!! Studs are designed to stretch longways (along the length) If you use the wrong pcd, you are applying stress sideways (across the diameter) and the studs WILL sheer. I was that soldier. No, that is only relevent with taperd seat nuts!
Apr 23, 2006 14:27:41 GMT
4" pcd wheels on a 3.75" pcd hub is surely 1/8" difference for each stud.
1/4 difference over the diameter so 1/8 on the radius.
Philj
Apr 23, 2006 18:29:28 GMT
If the pcd is within 2mm difference you can use wobble bolts.
Apr 23, 2006 18:51:06 GMT
I believe you can get offset studs too. I heard it mentioned somewhere else so it might not be fact but it sounded feasible
Apr 23, 2006 18:56:14 GMT
One thing that hasn't been mentioned, is are the wheels hub centric for your car? I'd avoid most of these ideas if the aren't.
