beany
Hmmmmm
was wondering if anyone had any tips or links on how to do the lace effect patterns on paintwork. I've got a MK£ golf tdi and the paint on the bonnet has had it anyway so thought I'd give it a go with some UV paint but can't find any links on it. I'm guessing its just a case of pulling a net curtain tight over the panel and painting over it but i could be totally wrong something like this
Maximum signature image height = 80 pixels
will
Try the google search at the bottom of the page A fair few on this site have had a bash at this with great results.
do you not just spray it with lace on the top, then peel the lace off ?
yep as easy as that, base paint, then stretch lace, waft of paint, wip it off, job done! my logo and striping on lace painted base mexican wrestling mask and striping on lace paint base striping over lace paint base
Yes, pretty much. Paint the panel with base coat of your colour choice, lay the lace over the panel, pulling it tight so it sits tight over the panel, but not so much that it distorts the pattern. Spray the 2nd colour choice of base coat over the whole roof and lace, keeping the pressure lower than normal, and keep the gun 90 degrees to the panel to minimise the amount of paint creeping under the material. When the paint is dry, remove the lace, and lacquer. Bob's your real dad.
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
Seth
beany
Hmmmmm
cheers people, your absolute legends. will get some paint and give it a go
skinnylew
Club RR Member Number: 11
lace patterned paint???skinnylew
@skinnylew
Club Retro Rides Member 11
Oct 10, 2010 18:18:55 GMT
idid the bonnet of my polo on the campsite at RRG10. came out fairly well. bonnet centre was matt black so the paint over the top was gloss black and gave a fairly subtle finish
Oct 10, 2010 20:40:18 GMT
i do keep umming and ahhing about trying this, especially using matt and satin black only. But struggle to fine a lace pattern i like. Someone did a spider web one on here, close but not quite....
