guy
i have been offered a 1986, 309, 1.6, for very little money. do they have any potential for tweaking? has anyone on here ever had one? i was thinking daily driver, but with a little tweaking here and there. possibly lowering, bit more power, new wheels etc. is the 1.6 the same unit thats in the 205Gti Any pics to give me some ideas would be great Guy
Mk1 Escort slowly rusting into nothing! But safely stored in a dry garage. Mk2 Golf, Low n' Loud
Pug 309arthurbrown
@GUEST
Sounds great. Not sure about the engines though. Although..... 309's are seriously cheap, even in 1.9GTi form. I'd say plump for a GTi straight outta the box, unless insurance is a major issue. I will be alot cheaper & easier in the long run, and give you a bigger grin from day 1.
Pug 309Dave Dorson
@cappuccinocruiser
my 2nd car was a 309 SRi, basicly the GTi 1.6 in a 309 shell with 5 doors.
My god that car was fun.
Plump for basic mods to start, filter, mongoose exhausts work well with them, mild cam and head flow.
Very much more stable, than the 205 out of the bends, in my eyes a better car.
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
yeh, they have a slightly longer wheel base than a 205 so they're more stable. could always stick an Mi 16 in there
burns
Apr 18, 2006 10:04:54 GMT
There is a nasty 1.6 as well, check which it is. There's the SRI, then there's a GL as well, about 80 bhp IIRC and the TCA suspension, not a proper wishbone with drop links to the ARB. If it an SRI it should be quite good.
Apr 18, 2006 10:16:58 GMT
I had this 1.6 5dr in 1990-91, GR-spec which was one up from GL, but still no PAS, EW, CL or anything, IIRC. Even though quite new it had a dodgy past, but there were no mechanical problems I remember. Carb-fed engine went pretty well. Big boot, but high sill. Got written-off rather dramatically, but driver error rather than any car problem.
Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
Apr 18, 2006 10:30:45 GMT
309 also has a wider rear beam, which many people retrofit to 205 GTi's as an aid to handling. I'm with pog. 1.9 GTi is so cheap I'd go straight for that one rather than spend money up-speccing a lesser car. Plus insurance for a standard GTi will probably be less than that for a tuned 1.6. Plus you get more toys inside, better seats, bigger brakes etc. Not really worth spending money on a boggo 1.6. Alternativley if you arn't goiung to tune it then stick with teh 1.6 as standard.
This space available to rent. Reach literally dozens of people. Cheap rates!
street
6.2 ft/lbs of talk
Apr 18, 2006 12:56:11 GMT
I think they're a good looking car, and ive seen many that are absolutely on the deck aswell, especially at the back! So slamming must be fairly straightforward I guess....
Apr 18, 2006 14:19:20 GMT
don't they have torsion springs in the back (like the vw bug and pug 205), so its just to drop it a few notches? And get some coils up front
Pug 309Dave Dorson
@cappuccinocruiser
Apr 18, 2006 14:22:17 GMT
don't they have torsion springs in the back (like the vw bug and pug 205), so its just to drop it a few notches? And get some coils up front indeed they do. but don't go too low, otherwise it messes the handling up. and uprate the shockers before you do drop it down.
Shortcut
Apr 18, 2006 16:08:16 GMT
don't they have torsion springs in the back (like the vw bug and pug 205), so its just to drop it a few notches? And get some coils up front indeed they do. but don't go too low, otherwise it messes the handling up. and uprate the shockers before you do drop it down. Yes indeedly. The 309 GTi has a reputation as one of the best handling fwd cars ever built. so it's going to be a hard act to improve on!
guy
Apr 19, 2006 14:38:26 GMT
thanks for all the info. i went to look at the car it all seems pretty good, the fuel pump is knackered i was standing there pouring fuel into the carb to try a get the fuel pump working, it did in the end, sweet engine only 54k on the clock.
it needs boot struts, little bit of paint here and there and a damn good clean out. the clutch also needs looking at??
Street Sleeper me thinks!!!!
Pug 309Dave Dorson
@cappuccinocruiser
Apr 19, 2006 14:46:13 GMT
carb?, not the GTi/SRi engine then
They are worth very little unless they are the faster ones to be honest, and as others have said, the GTi can be had for no money these days.
So did you buy the car?
Shortcut
Apr 19, 2006 15:06:51 GMT
boot struts is acommon prop on them and 205's. Struts probably cost more than the car is worth so best leave them. fuel pump and clutch eh! Again more than the cars's worth to fix. I'd offer to take it for free tbh as it will cost you to have the clutch done, which can be a pig on most Pugs. Other than that walk away, save up and buy a GTi
guy
Apr 19, 2006 15:35:04 GMT
well it didnt cost us much more than free? if i don't end up with it my mom will have it.
Pug 309Dave Dorson
@cappuccinocruiser
Apr 19, 2006 15:40:28 GMT
free is always good, you can always break even with free or make a profit on spares
GJM
Alloy engines; like communism- great in theory.
Apr 19, 2006 16:44:40 GMT
Wheres that 'This thread is worthless without (modified 309) pics' ? ;D
ishan
Apr 19, 2006 17:24:33 GMT
Shortcut
Apr 19, 2006 18:24:34 GMT
lovin those steelies 309 rallye look!
Apr 19, 2006 20:06:26 GMT
any one got a pic of the 309 that was in thundersaloons 2litre class (think thats where I saw it)? IIRC it used the engine as a stressed member that the suspension mounted to. from memory it looked farkin evil too. I'm possibly wrong, I'm not much good at finding pics on the net
