Nice work Alan,
I just realised that I forgot to add my pics of the milling machine move! I'll get them uploaded this week and add them here. They will prove that it wasn't just me that did the work..... ;D
jamesp
Shhhhhh, while the mrs wasn't looking I fitted the new inserts ;D how hardcore is breakfast at your house gotts use a axe on the chopping bord lol
Just caught up with this Alan, great work on the workshop etc.
The Maestro is stunningly clean for an old car.
I am sure you are chuffed to bits too.
purplevanman
Way too orangey for crows
how hardcore is breakfast at your house gotts use a axe on the chopping bord lol Stops the bacon n eggs running away ;D ;D
Welder, fabricator, general resto work
how hardcore is breakfast at your house gotts use a axe on the chopping bord lol LOL - that's just his butter knife. You wanna see what he uses to chop the bacon. ;D ;D
purplevanman
Today was spent mostly up the barn as it doesn't cost anything I managed to fix the passenger door on the landy so it now opens I also emptied it of all tools, ratchet straps, bags of sand, cement and lime and also filled a sack with rubbish, cor SEATS! That bit of rubbish clearing got me started so I carried on clearing rubbish but this time it was from the barn. Landy filled again so of to the tip Back home again after stressing out following pillocks that have no clue about driving and think because they can see snow in the field it must be slippery roads and drive everywhere at 20mph Got the chainsaw out and chopped a few logs on the front drive, just to cheer up the neighbours Whats next.. Well as there is 5 inches of compacted snow to sit on I thought it would be a good time to change the front pads in the Maestro, well better than waiting till it melts and turns into slush The pads passed the MOT but on the way home the meat fell of Doing the other side in the morning
purplevanman
Jan 25, 2010 11:42:09 GMT
I was asked by Bruce to warm up area 52 ;D Source 1 47kg gas bottle and remove valve, top cage removed for access and had to weld a bar to the base so my son could sit on the bottle and stop it turning as the valve was tight Valve out and filled with water work could commence, first cut while still full was the chimney hole then just a little hole to let the water out again Pipe for chimney is sourced from an old gate post, chuck it on the saw and go make tea ;D Next hole is the door Door cleaned and some steel cut and rolled to make the overlap Bit of tweaking and a good fit is achieved Overlap should rduce airflow enough to enable heat control next is air in and hinges etc for the door, wonder if this has a use ;D
purplevanman
Jan 25, 2010 14:50:40 GMT
a few hours go by and I do nothing, yeah right Door hinges, these are off cuts from a steel bar at a chain factory, the bit the machine cuts off to get a square end before cutting the rest of the bar into little pieces Pair up in the vice and drill the beejesus out of em and weld to the door with a bit of steel offcut door also needs a handle, this just happened to fall out of my knackered steering box, drill a hole in the door and bolt through and a couple of offcuts of steel to keep it shut We need air, but it needs to be controlled. Bit of pipe, cut a flap to cover the end and with use of nuts and a bolt weld it to the pipe and then weld it to the burner next is to weld in the chimney stub, after drilling holes for damper plate block valve hole with a bit more steering box. still a bit warm methinks Damper plate in with short bolt to show open or closed And a bit more steering box as a handle, note weld blob, thats to stop it going full circle or shutting chimney off completely I welded on a base to keep the floor cooler, fitted really well into a vaux wheel rim And complete I just need to fit a baffle inside now to make the smoke/heat travel around the burner to extract all the heat from it instead of going straight up the chimney
Jan 25, 2010 16:02:53 GMT
Alan, that's just flipping AWESOME & AMAZING!
Thank you. ;D
I love the fact its got bits of your Landy in it. And a wheel. And an old gatepost.
I tried to call you to say thanks personally, but it went straight to answerphone. Will try again a bit later.
Thanks again Dude.... ;D ;D ;D
Jan 25, 2010 21:09:01 GMT
Very cool, love the door handle.
Make a few of these and stick them on ebay for good money.
John.
Mark
Jan 25, 2010 21:24:58 GMT
Awesome on a stick B)
stefan
If it isn't broken fix it till it is
Jan 26, 2010 11:56:30 GMT
Lokks go only thing i will say is make sure you move the damper every week, as a chimney sweep i come across ones that have rusted solid from lack of movement
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
TS
Jan 27, 2010 18:45:25 GMT
Wow. Thats cool as f+@*
You could sell those.
purplevanman
Feb 12, 2010 20:19:46 GMT
Wow. Thats cool as f+@* You could sell those. just did wooohooo, £100 in the car fund ;D ;D just don't tell the other 1/2
Feb 12, 2010 20:45:47 GMT
Just been reading the build of the burner for Area52, I had the honour of relighting it the other day whilst minding the BBQ, quality piece of kit you've made it make the unit toasty warm ;D
purplevanman
Feb 15, 2010 23:08:04 GMT
Just been reading the build of the burner for Area52, I had the honour of relighting it the other day whilst minding the BBQ, quality piece of kit you've made it make the unit toasty warm ;D I have my uses ;D thanks m8
purplevanman
Feb 17, 2010 21:28:57 GMT
what ho! I seem to have been moved
purplevanman
Feb 17, 2010 22:45:19 GMT
Got a job at the moment to repair a length of asbestos guttering and replace another length. The one side was hit by the tractor and the whole length hit the deck I have removed the bracketry that held this up and took it home. I freed up the bolts that hold each bracket to the barns steel frame and replaced the threaded section which enables the gutter level to be adjusted. Actually I taught my 13yr old son to weld tonight so he welded the threaded section back on while I played with bits of Imp ;D Been stood a while but all nuts came undone ;D Brake piston looks good but bore is a bit iffy Will replace the adjusters will sit in some penetrating oil for a bit meanwhile up the Barn An RR member requested some plastic spacers, totally forgot but now on the case, taking 40mm nylon down to 25mm after drilling a 10mm hole up the center Just gotta cut to length now
skinnylew
Club RR Member Number: 11
Did i read that right: you are REPAIRING asbestos guttering?!?!?! surely thats a bit dangerous? lol nice new section for you as well
purplevanman
Did I read that right: you are REPAIRING asbestos guttering?!?!?! surely thats a bit dangerous? lol nice new section for you as well hehe does sound bad just got to cut the bolts, re seal and bolt back together, adding some more support brackets as I go, no cutting of gutter itself ;D The other side that was hit is being replaced by plastic but thats another post
