I'm not sure - Dolly PCD is 95.25mm, I have a feeling the GT6 is 95.5. Like those, those are TR6 ones. Triumph GT6 0 0 4x95.25 Triumph Spitfire 0 0 4x95.25 Triumph TR7/8 0 0 4x95.25 According to RR...
Last Edit: Apr 15, 2006 9:42:54 GMT by Lewis
What PCD are these things? Can you squeeze GT6 dished steels on them? Yes, GT6 steels will bolt right on. Careful though as they're not all 5.5J. 3.75" PCD by the way.
Apr 15, 2006 10:05:40 GMT
TR6 are 4.5" - they ain't going on a Dolly!
You're looking for Dolomite (obviously), Herald, Vitesse, GT6 and Spitfire fitments, but if you're feeling daring then there's Marina, early Lotus and quite a few Kit Cars and circuit specials that share the pattern. More daring? Late Lotus, Rover Metro, MGF, Maestro, Montego are the right PCD but there's size and bore implications that could complicate things somewhat.
With regards PCD - all the small Triumphs are 3.75" - the metricised measurement is merely to modernise it. GT6 and Dolly are the same.
Last Edit: Apr 15, 2006 10:07:36 GMT by rmad
Apr 15, 2006 10:08:55 GMT
Thanks. I'll look into the alternatives and post if I find anything interesting ;D
Apr 15, 2006 10:16:42 GMT
Apr 15, 2006 10:19:18 GMT
Don't think it could pull them off ;D
Apr 15, 2006 10:28:38 GMT
Most definitely.
Steels and chrome caps pwn.
*n
Apr 15, 2006 10:32:40 GMT
*Oof!* yes indeed... black green and chrome
Apr 15, 2006 10:57:13 GMT
Oof! Indeed! I need some big steels!
Last Edit: Apr 15, 2006 12:22:45 GMT by Lewis
Mr K
Apr 15, 2006 12:59:03 GMT
defo phat black steels with caps.... check out mine: when i can afford tyres.....
gingernik
'65 Beetle 1200
Apr 15, 2006 16:38:58 GMT
This thread has got me hankering for a Dolomite, and I don't know why!
How much for a reasonable MOT-worthy one? Need to work out if I can afford! ;D
Apr 15, 2006 17:07:40 GMT
This one with a breathed on 1300 went for a mere 50 quid! Only needed one small plate! The 1300/1500 square lamp ones fetch very little money at all. An MOT'able 1500 with twin round lamps, like mine, can be had for around 250-500 quid depending on condition, or you might even find an 1850 in good nick for that. Ideal for TR7 engine conversion!
gingernik
'65 Beetle 1200
Apr 15, 2006 17:33:56 GMT
That's good news...target for the summer methinks! Cheers for that.
Apr 15, 2006 17:42:00 GMT
No problems ;D - you know where to find me!
