Apr 10, 2011 19:42:39 GMT
regretsandromance: Better late than never. Sorry for the slightly shonky chop, I'm wearing a splint at the moment thanks to my recurrent wrist injury But here's your Civic modified. No rear door handle, RR sticker, Ronal Turbos, lowered, black vinyl on lower half. Hopefully it gives the Civic a bit more of a Retro feel. thanks for that man! the two tone is a stroke of genius! i think it has to be done
Copey
Apr 10, 2011 23:26:16 GMT
This is my new car, and a play around I've had with some ideas: *snip* One that someone else did for me that, do that!! love the red steels n whitewalls, suit it well!
Apr 13, 2011 23:38:14 GMT
Mitsubishi SpaceWAGON (got it on a technicality there I think). lowered, flared arches, large wide alloys, debadged grille, tinted out bumper lights, handles removed and a little Mitsi decal.
Right, for May let's have Low Off Roaders. Inspired by a particular Range Rover project that's going on at the moment elsewhere.
Wideboy Vitaras, slammed Range Rovers, pan-scraping Land Cruisers... you get the idea.
you can start with this!!!!!!!!!!!!!!
Hmmm, shonky! Potatoshop is not one of my skills. Chris
My wrist is still giving me trouble so I can't do as good a job as I want to. My potatoshop is similar to what RFChris did actually. Rear arch does not look good but I haven't the patience at the moment to make it look more convincing as a flared item. Reduced the sidewall on the tyres and the size of the alloys a bit to get it lower. These seem to have a lot of mechanical clutter underneath.
Ive done one also but it looks extremely similar to the ones done by RFChris and Volksangyl so ill not put it up, But seeing as ive started it ill carry on modifying it ;D
Chromed 3pc smoothies FTW!! Only one of these has been photoshopped. And it will hopefully be this low if he ever pulls his finger out and finishes it!
RF chris....that is superb.......problem is theres so much underneath, i don't know how low these will really go!!
Doesn't fit the theme but I just finished it.
I don't have photo shop so cant do my own. Anyone fancy having a go at these 2? Diahatsu Taft Mercedes Unimog
Not worked on the Daf suggestions, but I did spot this picture of an early Isuzu Trooper and saw potential to be had. Again, not my best work thanks to the wrist injury. lowered, roof chop, dehandled and delockedIdeally it needs better paint and different wheels, maybe chromed centres with coloured rims and some strong geometric graphics on the flanks. Interior should be acres of buttoned velour.
Did this one very quickly, just chopped and dropped it, stock wheels and everything, it would actually be quite easy due to the suspension, you could go mad low if you wanted, pretty sure the chassis is almost the same as a 2wd hilux chsassis except the surf has coils on the back instead of leaf springs.
EmDee
Committer of Autrocities.
Club RR Member Number: 108
The Photochop ThreadEmDee
@emdee
Club Retro Rides Member 108
a modern maybe, but heres one i made earlier
actually, just found this, its real.
Found a pic of a Volvo c303? so had a play with it: Lowered, de-locked and handled, wooden trim removed, rear side windows removed, vent added to panel on passenger door (the black thing is the vent)
Copey
hehe, looks like it should be doin militery ops in the desert somewhere!
The most in depth chop I've ever done, I'm quite proud of it. Original is here.
May 11, 2011 20:23:14 GMT
also found some more old ones I've done: original chop:
