blimey
Now THATS the sort of thing that should be getting magazine coverage over here!
Lol, I like the pressure gauge on the end of a hose poking through a hole in the dash
Last Edit: Apr 8, 2006 20:57:57 GMT by samyboy
"He's not the messiah, he's a very naughty boy!"
SteveP
300 Maniac
Gorgeous car and as always a crazy old 16v redblock with a monster turbo ;D I believe that the old redblock Volvo engines are just as, if not more tuneable than the later 5/6cylinder whiteblocks and stronger in the same instance. It'll be interesting to see what results! On a side note, I know of someone in Sweden is currently putting a 6cyl twin turbo engine (from an S80 T6) into a 360
Last Edit: Apr 8, 2006 22:13:21 GMT by SteveP
2003 - Volvo S60 D5 SE (Daily) 1989 - Volvo 360 GLT 1985 - Volvo 360 GLS
Nick
ive heard rumours that those 6cyl volvo engines arent as suitable for being huge boost monsters as the good ol 4 pots?
love a good volvo engine me.
this weeks car count "5"
gingernik
'65 Beetle 1200
Haha! That's superb!
Quote of the day: "This 600 hp, rear-wheel-drive, 2,900-lb Volvo has a permanently locked differential. Alfredsson says it's rarely a problem, unless you wish to turn, to which he injected: "You turn with the throttle." ;D
you turn with the throttle!!!!!!!!! those crazy swedes ;D ;D ;D
its not, its a 6cyl whiteblock found in the 960's
its not, its a 6cyl whiteblock found in the 960's Is that a straight 6 then?
Apr 10, 2006 17:59:25 GMT
Yep, it's an all alloy straight six, very compact and light engine actually, that's the engine that Volvo replaced the old Douvrin V6 with, the 760 was the last car to use the 3 litre Douvrin, then the 960 used the straight six. Lovely engines, I have a LWB 960 myself, only 200bhp standard, but the torque output must be pretty good because the 960's a rapid car for its size. They also use them in a transverse layout nowadays in the S80 and XC90, including as the T6 with a pair of turbos attatched and 270 bhp.
dub
Apr 10, 2006 18:02:10 GMT
that is class, such power
