Sept 8, 2010 20:31:04 GMT
Oh and have the bump stops been trimmed down on the front? I can remember when lowering Minors that you could regain some ride quality by chopping the bump stop in half if you dropped it by more than 2 splines. Matt I havent got a clue, will have to investigate I was told by a fellow marina enthusiast that the reason for the nasty thuds when I hit bumps is most likely because of the bump stop I'm not denying it looks good at the front but I cant be dealing with the ride quality being that bad! so if trimming the bump stop helps then so be it!
1993 Honda Prelude 2.2 SI VTEC Manual (Black) 1996 Ford Mondeo 2.0 GLX Auto (Green) Mint with 27K Miles 1983 Austin Ambassador Vanden Plas 2.0 Automatic - EFX 444Y (Silver)
Sept 8, 2010 21:00:41 GMT
I used to chop them in half. Don't remove them my mate did that and as far as i'm aware it smashed the kingpin through the inner wing and wrecked it.
Matt
Sept 8, 2010 21:26:42 GMT
ok buddy thanks for the info, ill have to have a look under there see whats going on
need to track down some marina lowering blocks for the rear!
