Aug 21, 2010 16:15:34 GMT
Hi all, I'm having trouble finding out what axle i have, its an english but don't have a clue what car its from, I'm at the stage of re-assembling and need to buy brake cylinders and shoes and other stuff but don't know what to ones to ask for?? ive attached a few pictures of axle for help of identifing No part numbers that are on parts such as drums or axle mount to anything when searched for on internet cheers for any help
Aug 21, 2010 19:31:10 GMT
whats the diameter of this backplate? what length is the axle? any numbers on the brake cylinders?
Aug 21, 2010 20:03:20 GMT
looks like mk2 stuff to me, not quite sure of you rear brake size but there is only two, the 9" and the much lighter 8". These are my 8" mk2's which i picked up after much ebay watchin
Aug 21, 2010 20:33:20 GMT
how wide is it backplate to backplate in inches? and has it got metric studs in it?
Aug 21, 2010 21:37:08 GMT
I'd say mk2 escort of some sort too. Anti tramp/ARB brackets rules out most early stuff, handbrake is different to corty 16e and mk1 capri/escort so that only really leaves escort 2 - capri 2 got a salisbury axle (except the 1300, which didn't get a rear ARB
v8ian
From what I remember of the axles, looks like a RS type from a mk2 escort, its the only small ford other than the Capri that had rear ARB, and as stated they came with the atlas in most cases.
The hogshead casting date computes to Jan 17 1980. So appears to be a Timken-design English axle, and if SOC says it's Escort-y, then I'd go with that. Did Mk2 Escorts use the transverse rod for the parking brake, as this has that feature on the housing. Norm
Team Blitz Ford Capri parts worldwide: Restoration, Road, or Race. Used, Repro, and NOS, ranging from scabby to perfect. Itching your Capri jones since 1979! Buy, sell, trade. www.teamblitz.com blitz@teamblitz.com
Aug 22, 2010 10:49:15 GMT
The anti roll bar mounts point to Escort ( Mk 2 ) or Capri . I wouldn't identify by diff or brakes , both are easy to swap from year to year. Width is usually the easiest place to start.
Aug 22, 2010 11:40:54 GMT
thanks for all the replies
The axle case measures 48" from end to end, i have not bolted the circular case that hold the brake components on the other side yet so cant give an exact measurement of these bolted to case.
your right in the fact that it did have the bar connecting the two handbrake mechanism's however I am using a different set-up so discarded the bar.
i believe the four bolts that connected the brake case to the axle were imperial bolts.
The internal drum size is 9" the diameter of the backplate is 11"
ive cleaned up the brake drum and it does have markings on it which read : 78 EB 1126 AA, on the side there is OA9A3, also there is information stating 229.4 MAX DIA.
64677490 & 0976 are marked on the brake cylinder but can find any info on that
i was wondering what the two brackets were for on the main case, would this be a rear ARB? are there any pics of how it was setup as would like to get this functioning again.
thanks again
Aug 22, 2010 17:24:13 GMT
The 9" ID brake parts are Capri compatible. As Kevvie says, it's entirely possible you have a custom or mishmash of parts. The brakes you show are also used on the Capri Atlas. So you may well have a 1980 Escort Mk2 Timken axle with Capri Mk2/3 Atlas brakes. The drums appear to be the 1-3/4" wide shoe type (4-cyl), rather than the 2-1/4" wide V6 type. The upper clamps, yes, are for an ARB, which the Capri used after 1972 in place of radius rods (1969-72). Norm
