Aug 23, 2010 17:41:57 GMT
Click picture for more
Aug 23, 2010 20:59:51 GMT
Thanks all , looks like its going the dropped with banded steels route , smooth the tailgate and lose the rear door handles , i can handle the expense of a set of wheels and the paint wont cost anything , as rmad says its a good base colour to start with , need something cheap to do in the evenings so thats the plan then
just came accross this thread after googling modified 406's did you eventually get anywhere with this? i did a quick photshop of one too
wrong stud pattern
for a nice 2-3" drop at the front, get yourself some 306 struts+springs. They fit into the hubs with no bother, but you do need to widen the ARB holes by a couple of mm, and the top of the strut towers need re-drilling to suit. The 306 struts normally only fit with 3 bolts, but they're actually drilled+tapped for four bolts... so I used all four This was mine, after fitting a set of 306 struts, with 30mm lowering springs! standard 406 on the left, standard 306 on the right, 306 with 30mm spring in the middle and a 306 saloon that had chopped rear springs:
I know they was the wrong stud pattern, but you get the idea
and a 306 saloon that had chopped rear springs: oh no it wasn't... no coil springs
Lol, oh yeah.. forget they had torsion bars either way... it was IMMENSELY low!
There was one I used to drive past regular, was dropped and had whitewall tyres on
I've got Rovers.
skinnylew
Club RR Member Number: 11
pug 406 estate ... Ideasskinnylew
@skinnylew
Club Retro Rides Member 11
was reading through the first page just about to formulate a reply about Taxi 1/2/3 when I came across a post by myself containing exactly that!! Only then did i twig the thread was from 2010 lol have a 406 Stadium prototype!
Ditch
Apr 16, 2015 11:19:09 GMT
THE_Liam
Yorkshire and The Humber
If at first you don't succeed... HAMMERS.
Apr 16, 2015 16:00:57 GMT
I've had mine a month now and I'm stuck for inspiration, which is fine as it's only meant to be a daily. Looking for some Coupe 16 inch starfish alloys, tints will be getting done, yellow fogs maybe... Fact is it's dull as hell, but it won't go under 40mpg even in heavy traffic or towing, it does 60mpg without trying on the motorway, has all the space in the world, is very comfy and suits me as a daily that I don't have to care about
andyborris
Apr 16, 2015 18:17:41 GMT
Just read the date on the first post!
Last Edit: Apr 16, 2015 18:33:49 GMT by andyborris
