Eventually I got a mornign on the Ventora, well, a couple of hours. Now I have to go into work to interview some geezers about a job starting monday, but hey.
Fan shroud and rad off, cleaned up the fan shroud, just needs finishing and painting
Rad looks like it could do with some help though.
Finally got finished on a job thats been annoying me and I've been putting off getting back to which is removing th heater assembly. Thanks to Vauxhall for hiding two of the screws inside the air chamber where you can only see them when the deflector is set to defrost... and someone appears to have glued the body in, which was a pain. But its out now.
So I can finally start looking at the scuttle properly.
Dropped the front splash tray out, this is 2" deep in grime and oily gunk. Lovely. At least its not rusted though!
Inside the front valance is just as icky. Reckon Cilit Bang! will shift this lot?
Oh well, off to work.
I'll do some more later.
