I am nearly finished assembling my engine but I want to polish the inlet manifold, turbo and alternator housing before thay go back on. I can borrow the dremel from work, I was thinkin a trip to bandq on the way home but I'm not sure what the best gear to get would be (has to be a cheap method too) what do you think? A tube of autosol and some generic polishing heads for a dremel? Whats the best type?
Also, is it ok to polish the alternator with it still in one piece or would the sward and curse word go in the cooling holes and cuase damage? Should I split the casing? Never opened an alternator before so don't want to risk busting it by opening it!
Cheers many ears
Cheers many ears
