Aug 14, 2010 13:37:57 GMT
Quick question - does anyone know whether the Bilstein shocks on the E36 328i Sport Coupe have the same dimensions as the standard shocks on the non-Sport 328i? Basically, will these fit? Thanks, hivemind. ;D
Aug 14, 2010 17:10:12 GMT
You change the strut as a bolt on unit and not an insert, so all e36 struts fit on your hubs, except M3 thats how they fit. an actual sport strut has a B6 insert, they are the only struts that do. (coilover platfrms anyone ) all other e36 struts are sealed units. If you are just dropping by 30mm, it probably won't notice much I imagine, sports are a weeny bit lower from stock. stock sport bilsteins and eibach/H&R springs = good idea. Takes a lot to beat a b6 billy IMO.
Aug 14, 2010 17:21:55 GMT
Thanks for this. I'm actually trying to raise the ride height (sacrilege, I know) - it's currently lowered 40mm at the front 30mm at the rear and I'm after a bit more clearance under the rear arches (tyres are rubbing), so I thought a 15mm or 20mm drop might do the trick - ideally I thought I'd just get standard OEM springs, but I have no idea how the 328i Sport springs differ to the boggo 328i ones, and I can't find any OEM 328i Sport springs anywhere. Does that sound stupid?
Aug 14, 2010 17:24:56 GMT
sport stuff is BMW only. there isn't a lot of it on the cars, but BM only for those. you can get the rear billies from ECP, but they are more expensive than main stealer- WTF?! I probably have a set of stock sport suspension at work secondhand if you want. its what I do- I break BMWs
Aug 14, 2010 17:25:49 GMT
But there is some difference in suspension around 1992, which makes compatiblity a bit more challenging.
Not sure about the change and the precise date, but realoem.com should be able to point you out.
Click picture for more
Aug 14, 2010 17:30:36 GMT
thats mainly for anti roll bars and links. early cars use a shorter anti rollbar with drop links on the struts, later ones have lollipop mounts on the wishbones and a longer bar mounted slightly further forward on the chassis
Aug 14, 2010 17:33:15 GMT
I probably have a set of stock sport suspension at work secondhand if you want. its what I do- I break BMWs You could well be my saviour. If you've got a set of stock Sport springs (or even just the rears), I'd be forever endebted... ;D
