All items can be collected from LS29, smaller, less weighty items can be posted.
Set of four BSA alloy wheels, 17" with 4x100 PCD and ET-40 shod with 205/40R17 tyres with approx 4-6mm tread.
They have been lovingly hand slathered in black smoothrite by a trained chimpanzee. ;D
SOLD
Sealey Hydraulic hub puller (Part no PS993), good condition with very little use.
£55 collected.
Peugeot 306 14" alloy.
£25 collected
Lucas 4cu airflow meters.
Standard bore AFM (as per range rover/ rover sd1 etc) £30
Big Bore AFM (can be used as an upgrade on lucas 4cu systems) £60
Lucas 4cu ecus
1x part number PRC7440 (lucas number 84941A)
1x part number PRC4764 (lucas number 84477D)
Both believed to be rangerover units. £35 each.
TRW brakepads, unused. £12.
Fram oil filter PH2821A for Jensen interceptor, various landrovers and TVR tasmin. £6.
Sanden SD508 aircon compressor.
£70 Collected.
E-flite blade r/c chopper PNP version, very little use and comes with a DX6i rx.
£140.
PPC mags, most available from issues 1 to 50.
£3 each
Tamiya Model kit, few bits taken of sprues but all present.
£20.
Hasegawa model kit
£15.
Alpine amp.
SOLD
Dizzy cap and rotor arm for rover v8
SOLD
Forte Specialist Injector Cleaner
£12.
Big b**tard bass box. Has a small hole in the cone, covered with duct tape, jobs a good 'un.
£15.
Steelies both 4x108pcd, one 165/65R14 and one 185/65R14 Approx 4mm tread on each
£7 each.
Pug 306 rear wheel bearing (drum brake)
£5.
Mintex M1155 pads for Austin Princess 4 pots
SOLD
DS Performance pads for volvo C70 (and maybe V70 etc not sure)
£30
Jaguar bike roof rack. No keys and not sure which jags it fits.
£14
SOLD
£55 collected.
£25 collected
Lucas 4cu ecus
£70 Collected.
£140.
£3 each
£20.
Hasegawa model kit
£15.
Alpine amp.
SOLD
SOLD
£12.
£15.
£7 each.
£5.
SOLD
£30
£14
