Mar 27, 2006 19:50:46 GMT
had a play with the sanding block today (p80). anyway, after a quick rub on the filler it was fine but when i put it on the paint the edges of the paper got kinda gummed up, and when i pick it off it takes some of the grit off the paper! is this cause I'm useing to fine a grit or cause it nasty quality paint? ta.
Mar 27, 2006 20:21:20 GMT
What paper is it ?
80 Grit is only really good for shaping Filler, too coarse for anything else really
slater
Club RR Member Number: 78
sandingslater
@slater
Club Retro Rides Member 78
Mar 27, 2006 20:32:18 GMT
I feel you pain, ive been doing this non stop for the last 4weeks. ~3 hours a nite every nite (well nearly I'm not that sad! ) and I'm still only half way through! I have had simlar problems. I found some paper that was suppose to be 'anti clog' (3M stuff, green, 80 grit) supprisingly it does work pretty well. I tryed some 60grit emery from work and it clogs relly easy in comparison. As allways the the more you change the paper the less effort you require. Try a DA sander for the paint work, cant sand filler with them but they are a arm saver on straight metal.
Mar 27, 2006 20:46:08 GMT
CR500Dom - its p80. not sore on the brand. slater - whats the da stand for? ive got a mains one and an airline one. last time i used the leccy one i found i had more filler on the wing than i thought!
Mar 27, 2006 20:46:59 GMT
sure even!
slater
sandingslater
@slater
Mar 27, 2006 20:51:06 GMT
lol i have no idea
Last Edit: Mar 27, 2006 20:51:35 GMT by slater
Mar 27, 2006 20:56:12 GMT
DA is dual action.
P80 is a bit rough for paint if you do use it don't press down so hard but you are probably better swapping to a lighter grade
thevert
Mini builder
Mar 27, 2006 20:58:08 GMT
DA- dual Action its orbits and turns. Kinda like you going in circles and ur hand spins the other way heh. ;D
том
"If in doubt, flat out!"
Mar 27, 2006 20:59:34 GMT
go for 3M or Bodyline, both of which can be found at your local Unipart, where you'll find great service, cheap products and a friendly staff ;D
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
Mar 27, 2006 21:24:41 GMT
go for 3M or Bodyline, both of which can be found at your local Unipart, where you'll find great service, cheap products and a friendly staff ;D dodgy staff though
sandingrustingdeathtrap
@GUEST
Mar 27, 2006 21:39:04 GMT
not at my local unipart i wont
Mar 27, 2006 22:15:17 GMT
i think the electric one just spins. the airline one spins then above a certain rpm wobbles into a bigger area. so there sa and da then?
Mar 27, 2006 22:23:47 GMT
btw how long should it take to sand down a capri?
yes, sounds like you're right on the sanders.
I use P80 on filler only for taking the rough ridges etc oout and occasionally on rusted metal. I use P120 on paint. Works a lot better, doesn't gouge, removes paint much better.
How long to sand down a capri? well, I've been doing my Ventora which is only slightly larger andf thats taken about 4 months so far LOL.
I sanded a victor Estate mostly by hand (used DA over the roof and bonnet) and that was done in half a day but the prep was all done before I started.
I'm sanding the filler on the roof chop on my bug at the moment and it's taking chuffing forever
Make sure you clear the paper by blowing the filler sandings off it every couple of rubs and it will stop it clogging. Make sure the filler has completely cured, if it's only 99% of the way there it will gum the paper up and the dust won't blow out.
How long it takes to sand a car is almost impossible to say, as it varies according to how many grains of sand you are using.
I actually once sanded a mini using only 1 grain (well actually 2, after I lost the first one) and it took over 4 years. However I later developed a technique which allowed me to hold several grains all at once, thus shortening sanding times dramatically. Of course, I am not going to reveal this secret on a public car forum!
Mar 28, 2006 10:31:10 GMT
Has anyone tried the flexible sanders from PNR? Custom Car used one in a feature on bodywork and it looks good. I haven't much bodywork to do on the Volvo, but I'm tempted by them. www.flexiblesanders.co.uk
Peugeot 307sw - Suzuki SV650S - MX5.
Mar 28, 2006 10:33:04 GMT
I have a set. I got the pro-kit. I would never have got the flanks on my Venotra half as nice without them I reckon. But then again I am a bit of a ham fisted amateur.
Nathan
Club RR Member Number: 1
sandingNathan
@bgtmidget7476
Club Retro Rides Member 1
Mar 28, 2006 12:36:50 GMT
Mind the PUN but i know nothing is better than doing it by hand but I invested in a DA and a angle sander and would never go back. but there is always those places where the machine cant get too
