hi folks ,have just managed to get my hands on a unfinished project...!its a nissan skyline gts 93/94 reg ( L).
the car is white in colour and complete ..
the good bit is the engine spec !!!!
this has had a full rebuild at major expense
here we go..
bottom end fully built
eagle rods h section
mahle de comp ( 8.1.1 ratio ) and ceramic coated and file to fit rings.....( bring on the boost )
new crank
race spec shells acl
jun oil pump ( 500 quid)
head stripped and cleaned checked for cracks etc
gtr spec exhaust cam
fully port matched and flowed ( machined out exhaust ports)
arp bolts and studs through out
hks 1.6mm steel gasket
turbo is a hks ( garrett) t300s ( which was recently bought form mgt tunning.( big single good for 650 bhp fast spool)
mounted on a tubular top mounted equal length manifold
this connected to a 3 inch exhaust with lambda and wide band take offs
tia;l 50mm ext
fuelling is provided by a porsche gt3 fuel pump ( 1000 new from porsche)
800cc injectors
boost is controlled by apexi power fc commandor ecu
6 paddle cluth rated to 650 plus
85mm throttle
custom made inlet equal balance trumpets
tomei cam belt fitted
intercooler 120mm thick 290 tall core 600mm wide
3inch pipe work through out
fully polished cam covers and carbon trim
rs elbe 3 spoke wheels 3 piece split 17
with 255 40 17 rr
235 45 17
nardi torino steering wheel..
3inch to 4inch trial super dragger system
skline gtr 33 fibre rep N1 vents
then there is a full rolling shell with diff
etc ...
looking for 5000 ovno on the engine complete
will break but prices will be individual..
pls contact me on 07756392332 or dan on 07766767874
the car is in the midlands junc 10 m42...
cheers dale
few pics for ya
![](http://img.photobucket.com/albums/v393/solomk1/skyliner006.jpg)
![](http://img.photobucket.com/albums/v393/solomk1/skyliner001.jpg)
![](http://img.photobucket.com/albums/v393/solomk1/skyliner008.jpg)
![](http://img.photobucket.com/albums/v393/solomk1/skyliner010.jpg)
![](http://img.photobucket.com/albums/v393/solomk1/skyliner011.jpg)
![](http://img.photobucket.com/albums/v393/solomk1/skyliner013.jpg)
![](http://img.photobucket.com/albums/v393/solomk1/skyliner015.jpg)
here we go..
new crank
tia;l 50mm ext
800cc injectors
85mm throttle
with 255 40 17 rr
235 45 17
etc ...
cheers dale
few pics for ya
