Stu
Mar 27, 2006 11:19:38 GMT
Hiya, welcome along. I was going to suggest weight reduction too - sounds like you are doing pretty well in your 0 - 60mph quest already though, those Volvo's much be pretty quick on the road even with the autobox. I reckon some good tyres and dump the back seat, spare wheel and jack to save weight and you'll be well on for 7 secs!
Mar 27, 2006 11:25:59 GMT
welcome - cool ride! love those old volvos
Likewise, me immediate thought was "strip that beatch out!"
burns
Mar 27, 2006 11:47:35 GMT
I am now also looking at a camo/military type paint job too!! Damn you Penski! Nice one. Penski's mission to convert the whole of OCUK's membership to nato green retro rides takes a step closer to completion...
Mar 27, 2006 12:03:25 GMT
I am now also looking at a camo/military type paint job too!! Damn you Penski! *Rubs hands together* Excellent! Nice one. Penski's mission to convert the whole of OCUK's membership to nato green retro rides takes a step closer to completion... You knows it. I won't rest until Fox sells his Mondeo and admits that there is more to choosing a car than cup holders, optional extras and how many stars it gets in What Car. *n
Mar 27, 2006 12:10:59 GMT
The only time Fox sells his Mundano will be to buy a 5 series. Diesel.
;D
Mar 27, 2006 13:24:58 GMT
Volvo love. ;D Strip it. All the extra trim weighs a bit. I reckon on the stuff I've ripped off of mine weighed about the same as me! Don't forget, snow camo for the real Swedish style.
Peugeot 307sw - Suzuki SV650S - MX5.
street
6.2 ft/lbs of talk
Mar 27, 2006 13:28:50 GMT
What size/type of turbo do these volvos have?
Obviously a bigger one would break the budget, but just curious.....
Volvo 480 - Do i qualify :pBenzBoy
@benzboy
Club Retro Rides Member 7
Mar 27, 2006 13:29:01 GMT
Regarding the actuator: do you have a bleed valve between the actuator and the turbo? Can you not just adjust this to get the actuator to kick in later? Or am I missing something?
Mar 27, 2006 16:07:40 GMT
Regarding the actuator: do you have a bleed valve between the actuator and the turbo? Can you not just adjust this to get the actuator to kick in later? Or am I missing something? I am already playing with this via the bleed valve, but the actuator wont hold PSI solidly above 6. the spring in the actuator does not provide the same resistance it once did!! In regards to the turbo, they run a T2 iirc, and some people have done a hybrid T25 jobby on them.
том
"If in doubt, flat out!"
Mar 27, 2006 17:54:43 GMT
Roof chop, matt black, black alloys, air intake instead of one of the head lights, and 2 yam R1's in the back... ZOOOOOOOOOOOOOOOOOOOOOOOOOOOOOM!!!! ;d ;d ;d
1988 V8 Rangey Bobtail :: 1968 Volvo Amazon 133 Ratrod :: 1977 Land Rover 88 :: 1985 Opel Monza GSE :: 1983 MKII Fiesta
thevert
Mini builder
Mar 27, 2006 20:05:41 GMT
May i sugest adding a bigger intercooler. Just fitted a saab one to my flatmates 200sx , all that was needed was a bit of hose. also, u may want to add more fuel (need a resistor, its like 20p! 10-15psi should be ok for the standard fuel pump)as to much air not enough fule = melted pistons! Run it on optimax to, helps prevent knoking. youll be laughing
Mar 27, 2006 21:49:22 GMT
May i sugest adding a bigger intercooler. Just fitted a saab one to my flatmates 200sx , all that was needed was a bit of hose. also, u may want to add more fuel (need a resistor, its like 20p! 10-15psi should be ok for the standard fuel pump)as to much air not enough fule = melted pistons! Run it on optimax to, helps prevent knoking. youll be laughing Have you seen the size of the standard one?! Its bigger than most of the aftermarket ones available!! I'm going to be using higher octane fuel though I'm going to see my mate tommorrow, hes going to help me adjust the pre-load to see if i can stop it venting from 10-6 on power Fingers crossed eh!!
Mar 27, 2006 21:54:05 GMT
Get a tank of Tesco's 99 RON and add some Millers Octane booster - 101 octane should give it some kick ;D
Mar 27, 2006 21:58:44 GMT
Get a tank of Tesco's 99 RON and add some Millers Octane booster - 101 octane should give it some kick ;D I think it might need a re-map to take advantage of that level of octane?! Or am i being noobish
Mar 27, 2006 22:00:58 GMT
who cares, give it a whirl anyway ;D
Last Edit: Mar 27, 2006 22:01:08 GMT by Lewis
the advantage the octane normally gives is through advance, but this is a turbo car and that extra octane means more BOOST!!!!
J
the advantage the octane normally gives is through advance, but this is a turbo car and that extra octane means more BOOST!!!! J OK, I'm sold
