Mar 26, 2006 19:59:41 GMT
ok the kadett is driving me nuts now tryied everything to get the ecu wired and it just refuses to go got no spark and the injectors won't work anybody good with wiring fancy coming and getting it going? getting close to giving up now i'll pay good money and may even throw in the wife ;D ;D
Last Edit: Mar 26, 2006 20:28:19 GMT by Deleted
Mar 26, 2006 20:11:50 GMT
:)Any chance of a pic?
;D Of your wife that is!! ;D
Mar 26, 2006 20:28:18 GMT
is it the ecu for the engine youve put in or have you had to splice 2 harnesses? i remember when we put a 2.2 into jarvis's manta we had to use the manta and carlton harnesses. some of it was straight forward plug in, but some had to be wired elsewhere. maybe you need to swap some wires? and thats the extent of my knowledge.
Mar 26, 2006 20:31:08 GMT
i pulled the entire wiring from the piazza and seperated the engine/ecu wiring just used the kadetts wiring to power it
Mar 27, 2006 10:00:16 GMT
Hmm this sucks... if I could help.. I would
Mar 27, 2006 13:23:57 GMT
Sorry to hear of your troubles, i'll post to get it back to top of list. Surely someone is handy with wires, what about cr500dom?
Mar 27, 2006 17:40:17 GMT
Was that wiring diagram I sent you before no good?
Do you have any output at all from the ecu?
I will see if I can see anything obvious on the diagrams.
How about crank sensor (if it has one)??
Mar 27, 2006 18:15:26 GMT
Hello mate, Is the missing (Soon to be replaced) Turbo computer anything to do with it do you think ? Will you want another ECU to try The Axle donor is currently complete so if you want anything to try .......
Last Edit: Mar 27, 2006 18:49:58 GMT by CR500Dom
Mar 27, 2006 18:37:54 GMT
Hello mate, Is the missing (Soon to be replaced) Turbo computer anything to do with it do you think ? Will you want another ECU to try The Axle doner is currently complete so if you want anything to try ....... This gives a feed to the dizzy as well as many other things so I would have thought this could be it.
Mar 27, 2006 23:07:01 GMT
cheers for the sugestions guys the wiring diagram is slightly different but has helped alot on some parts but are different on others .from what i can tell the crank sensor is part of the distributor , i can get about 1/2 a volt from the ecu when powered up and it now runs the fuel pump relay ok but still no spark or firing on the injectors, the more i look at it it does look like the turbo computer is going to be needed . have you got your one yet dom ? i may take you up on trying your ecu cheers mate
Ok I`ll sort some stuff out with Mark up here..... He has about 3 Piazza turbos in bits already including a few turbo computers etc I`ll try and bring a selection down with me at the weekend if you want ? Cheers Dom
Mar 28, 2006 11:44:36 GMT
Ok I`ll sort some stuff out with Mark up here..... He has about 3 Piazza turbos in bits already including a few turbo computers etc I`ll try and bring a selection down with me at the weekend if you want ? Cheers Dom great stuff dom cheers mate
