RobinJI
Jul 29, 2010 19:48:36 GMT
Hi, Just a warning that there will be roadworks on the A358 between Taunton (M5 J25) and Illminster (A303) for the next 2 weeks.
This road is one of the main routes between the M5 and the A303, so it'd be worth checking that your planned route to the Gathering doesn't involve it.
I'll report back closer to the time to let people know just how disruptive the road works are being.
Cheers, Robin.
RobinJI
On closer inspection the road works are only there in the evenings between 5 and 8pm, so unless it's those times, then don't worry.
Chops
Don't touch me I've been somewhere
Club RR Member Number: 36
On closer inspection the road works are only there in the evenings between 5 and 8pm, so unless it's those times, then don't worry. Ah curse word, I was expecting to pass through there about 8ish on Friday Thanks for the heads-up
purplevanman
Way too orangey for crows
On closer inspection the road works are only there in the evenings between 5 and 8pm, so unless it's those times, then don't worry. Ah curse word, I was expecting to pass through there about 8ish on Friday Thanks for the heads-up you don't need to go that far down, get of at A39 Glasto turning
