Well some of this stuff just needs to go as no longer have cars to fit it on or time for major projects.
First off.
Alfa GT junior exhaust system from the manifold back, never fitted to a car and dry stored, yours for £50 ono
Next up, mk3 gold parcel shelf, missing one mounting block but if you have one with silly speaker hole's this is ideal replacement.
£5
Next for all the serious modders, Corsa c electronic power steering column unit, power steering on your retro plenty of how to guides around.
Really want sensible money for this but feeling generous, £50
Vauxhall inlet manifold with injectors, not sure what off though, as new.
£25
Pickinick hamper, missing tie down straps
£5
15" alloy wheels, 4x100 et35 vw etc with 195/45/15 rubber although the rubber is scrap to be fair, can be removed if required 6.5J I remember right.
£50
I also have a pair of NOS 73 avenger headlight
£25
6 strombergs from a avenger one on manifold.
£10
Nitro rc car used once needs a new spring plate on the front and lower arm mounting bar straightening, was brand new with all radio gear and fuel, glow start etc, just bring your own batteries.
£80
Any questions or further pics required just shout, you can collect or I can bring to gathering, will be there from Friday eve onwards.
If I have not been on here give me a txt or ring on 07967212369
;D
First off.
£5
£25
£5
£50
£25
£10
£80
;D
