Nick
Mar 23, 2006 15:11:43 GMT
have any of you guys ever come across a fill from the bottom gearbox?
i am repaying a favour i owe to someone, by changing their gearbox oil in their too modern bmw e36 328 auto.
what a bloody game, the fill plug is at the bottom, so the usual approach of squidge the squishy bottle until you can't squidge no more has so far just left me covered in atf.
trying to locate a pump of some sort for tomorrow morning. so i can use the power of my arms to pump from the bottle up into the gearbox,
are these fill from the bottom boxes normal on auto cars?
i know this isnt retro, but basically it solidifies my hatred for working on anything with more than 3 moving components and/or newer than 1912.
this weeks car count "5"
bstardchild
Club RR Member Number: 71
Rant: fill from the bottombstardchild
@bstardchild
Club Retro Rides Member 71
Mar 23, 2006 15:23:32 GMT
Has it got a dipstick for the the auto box fluid level?
I always fill my autos up thro that - it doesn't take that long either - warm the fluid up in their containers in a bucket of hot water
antdat
Mar 23, 2006 15:24:01 GMT
auto cars i have done you always fill from the dipstick, never heard of one you fill from the bottom :s
Last Edit: Mar 23, 2006 15:24:25 GMT by antdat
Nick
Mar 23, 2006 15:49:57 GMT
don't think this one has a dipstick, yeh i hadnt come across one that i fill from the bottom. but apparently i do and its such a mega crapola idea.
antdat
Mar 23, 2006 15:53:45 GMT
how do you check the level if it don't have a dipstick?
Nick
Mar 23, 2006 16:12:12 GMT
to check level, you take filler plug out, start engine with car in park, and if a small stream flows out. that means its level. if nothing. then means you add more. its a completely rubbish idea. but i guess based around the selling point of "lifetime gearbox..never need to change oil" which is a load of old honk anyway.
don't spose anyone got any bright ideas of what could be used to pump it in,and that i can get hold of tomorrow?
think i'll tell him he should have just taken it to agarage and let them rip him off!
Rant: fill from the bottomBenzBoy
@benzboy
Mar 23, 2006 16:17:24 GMT
You can get containers that you pressurise by hand-pumping them - WaxOyl sprayers and that kind of thing. Don't know whether you could adapt something to "pump" atf?
'tis a sh!te set-up... no doubt done so that the dealerships owns your soul for the lifetime of the vehicle.
bstardchild
@bstardchild
Mar 23, 2006 16:21:46 GMT
don't spose anyone got any bright ideas of what could be used to pump it in,and that i can get hold of tomorrow? Drill pump works fine ;D
Mar 23, 2006 16:26:30 GMT
Can you do this, with the filler tube going through a bung?
Peugeot 307sw - Suzuki SV650S - MX5.
Mar 23, 2006 16:46:52 GMT
Most modern auto boxes are like this, you fill a special container with gear oil, then it hangs from the bonnet catch or any point that is higher than the gearbox, there is a tube that runs from the container and screws into the bottom of the gear box, you then fill the gearbox by switching a lever and the oil flows into the box. then you check the level by connecting a diagnostic machine to the vehicle and waiting untill the gearbox oil reaches a prescribed temperature, when the correct temperature is reached you undo the filler plug and either add more oil or drain some untill there is only a small trickle coming out. job done.
The down side of this is you need three things
1: the correct filling container for that vehicle 2: the correct diagnostic machine 3: a vehicle hoist.
If you rely on the methods for filling older auto boxes there is no way you'll get the correct level.
Nick
Mar 23, 2006 17:00:35 GMT
well i have the car on a ramp so that helps, but i have very insufficient tooling available to me, so basically i just got to fill the b*stard in as many bodgey type ways as i can and whack as much of the stuff in until i give up.
i really hate this. my e30 is lovely to fill up, find a suitable hole in the body stick a tube through, and let gravity do the work.
wonder if he will mind me stripping out his car and converting it to manual? i'd probably be better off doing that.
Mar 23, 2006 17:09:33 GMT
sounds like fun, don't u just love moderns on a completely different note, my wifes n reg scrote td decided to set itself on fire tother day after refusing to start. turn the key and all the dash lights come turn to start and.... nowt. quey smoke billowing out of the dashboard. let the smoke clear and call the aa man. " its the fuse board" says he"commom fualt on these old escorts". so of i pops down to the scrappy ,20quid later and new fuse board in hand. fit it. turn the key and....... nowt. aaaaaaaaaaaaaaaaaaaargh!! any ideas?
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Nick
Mar 23, 2006 17:11:31 GMT
maybe fuse board setting on fire and smoking it up, melted somewires somewhere along the lines? ideas aside from that, beat the car with a stick and "learn it good" for being modern and awkward
Mar 23, 2006 17:17:42 GMT
You've obviously let all the smoke out of the wiring loom, just get some more smoke and syringe it back in!! then quickly wrap the wires with electrical tape to keep it in. Sorted ;D
Mar 23, 2006 17:26:46 GMT
I'm thinking melted wire somewhere but i just don't seem to care enough to go any further ny one want an escort in good fettle with a small problem?
"quote hairnet"
[/quote]
Mar 23, 2006 17:30:07 GMT
Escort fusebox on a mk6? I'll have a word wi' my bro, he's replaced loads of those!
My fleet: Suzuki GSX-R600Y SRAD with bald, melted tyres A borrowed Mondeo
Mar 23, 2006 18:54:35 GMT
I'm thinking melted wire somewhere but i just don't seem to care enough to go any further ny one want an escort in good fettle with a small problem? Swap you for a welder
Mar 23, 2006 18:59:14 GMT
I'm thinking melted wire somewhere but i just don't seem to care enough to go any further ny one want an escort in good fettle with a small problem? Swap you for a welder You'll need that welder if you have an escort ;D
Mar 23, 2006 21:14:27 GMT
some of the mercs have a very small dipstick or something at the very top iirc.
i know some of them have a (main dealer only) seal that breaks when you try and check the level.
if the atf level is wrong it'll fubar something, usually expensive.
