Mar 22, 2006 18:09:55 GMT
like ive got a broken bulb.
id assume id need to add a resistor in the circuit to make it think its a bigger bulb right?
if so, anyone know what size resistor?
if not, what?
Mar 22, 2006 18:51:13 GMT
I'm a bit confused on this one... wouldn't it be easier just to replace the bulb / holder? Or am I missing something?
Mar 22, 2006 18:52:22 GMT
replace the bulb holder with what?
Mar 22, 2006 18:55:42 GMT
probably should make myself a bit clearer.
I'm putting the sidelights where the indicators are
and indicators where the sidelights are (like the beetle)
cept when i do, they flash fast, like ive broken the bulb.
i assume this is because the indicator bulb is a lot bigger than the sidelight bulb, therefore it thinks its broken and flashes like it would if it was broken
Mr K
Mar 22, 2006 18:58:39 GMT
Arnt your side lights in your headlamps?
or are we talking side repeaters here?
Mar 22, 2006 19:02:19 GMT
my sidelights are in my headlights yes.
which will now be my indicators.
ive checked it out, they are pretty bright, and noticable from a distance even with high beams on.
my sidelights will now be where my indicators are. ill have clear lenses by the weekend.
now, back to the original question ;D
Mar 22, 2006 19:11:09 GMT
Sidelight bulbs are 5W and indicater bulbs are 21W, so yeah, that's why it's flashing too fast.
Mar 22, 2006 19:23:25 GMT
good stuff.
what do i go into maplins and ask for then? a 16w resistor?
or do you ask for it in ohms? in which case id need a 9ish ohm resistor (a level physics does come in handy ;D )
Mar 22, 2006 19:29:13 GMT
What car have you got mate? Just wondered if a 21W bulb could be fitted instead of messing around with resistors. Indicators in headlamps aren't always a good idea, as when the headlamps are on the indicators aren't so visible as when they are seperate.
Mar 22, 2006 19:33:03 GMT
its a mk2 escort.
but has mk1 golf headlights.
Mar 22, 2006 19:34:04 GMT
bulbholders and bulbs look like this (minus the chavvy blue lights)
Mar 22, 2006 19:34:49 GMT
You can get the 20W bulbs in the same size. I have them on the front of my Vespa. One is a 5W at the mo and it blinks like an old perv with a twitch though.
Mar 22, 2006 19:39:01 GMT
ok mate, know anywhere in particular?
Mar 26, 2006 13:28:37 GMT
have photoshopped the hieght, and added a bit more sparkle to the sidelights, but apart from that you get the idea. the indicators look really cool now
Mar 26, 2006 14:21:13 GMT
cool! nicely different.... i know the golf boys have been doing such things for a while but it's not widely seen. was thinking of doing such a thing (before you mentioned it, honest!) on a mk3 polo, or have both sidelights and indicators in the (clear) indicator units. oh, and beetle owners were doing it in the 60's
Mar 26, 2006 14:24:55 GMT
ok mate, know anywhere in particular? halfrauds any motor factors borrow some from the local scrappy the forklifts at work don't cost a lot either
Mar 26, 2006 14:34:17 GMT
lol, you cannot get the same sized 21w sidelight bulbs, i looked everywhere. what you can get is bulb '435' which is basically the same as a sidelight sized bulb, cept one of the pins is in the wrong place. cut the second pin off, and if fits nicely in the sidelight holder you then have to use some tailight repair tape on the bulb to make it orange plus its a lot brighter (obviously) than the 5/4w bulbs and makes the whole headlight glow up orange, as can be seen in the pic oh, i got the idea after seeing it done on a beetle. eventually ill cut the indicator sections out the bumper, cut up a spare bumper length to replace them, lead fill and rechrome the bumper.
Mar 26, 2006 17:35:34 GMT
I keep thinking about doing something similar to the Mini - using Landrover stop / tail lights instead of the front indicator. It`s the same lense so could have orange or clear lense or paint the bulb ... Hmmm, one day ...
Mar 26, 2006 19:22:46 GMT
Hmm, I'm not convinced. Smacks of the LaxFlower lot to me
Mar 26, 2006 19:45:36 GMT
also, using capri tacho and speedo in the escort dash, with them fangled LED bulbs look like this:
