MiataMark
Club RR Member Number: 29
and when you come out of Improbability Drive;
"...we have normality, I repeat we have normality. Anything you still can't cope with is therefore your own problem..."
but be careful if you go of course you might end up in the "Naughty Corner" and that definitely isn't normal.
Tarting the old girl up for the long & lonely drive to the Gathering and I considered sticking on a 'Powered by CUMMINS' badge but then I found a little something in the USA which adequately describes the zen journeying of the Goddess. If you see a Sperm Whale and a bowl of Petunias by the side of the M40 in a couple of weeks time you will know it worked AWESOME! WANT!!
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
Frankenhealey
Club RR Member Number: 15
Aug 13, 2019 21:12:37 GMT
This weekend we had the Good , the Bad and the Ugly The Good was that we were booked for a pre-Gathering day out with the Goddess at the Purbeck Rally. It was only 2 miles away but the route to the commercial pitches is over a half mile of rough field simulating the bumps and jolts of 180 miles of dual-carriageways and motorway to Shelsley Beauchamp. First thing was to see if a desk-bound 66 year old man could load the car on his own. The whole thing was designed for owner operator use but it was a long time since I achieved it on my own. No pictures of the loading as I was on my own except for Bob the Dog and he was no halp at all. The 35mph 'breeze' did give me a slight assist in removing the cab cover halfway across the field and have a picture of the Healey lurking in the grass waiting to be loaded It took about an hour to get the covers off, load the main and winch batteries, tilt the bed, get the ramps out, the car winched on, bed down, ramps in and the car strapped down. MISSION ACCOMPLISHED. Then the job of threading a needle while blindfolded and wearing oven gloves or the fitting a new injector pipe. This would hopefully stop the diesel leak abnd slight misfire. Bad pipe New pipe fitted (note the lack of any room or clearance) Connected to the pump and bled A quick clean up and move the truck to the gloomy side of the field in the hope that no scallys catch sight of it with the Healey loaded and 4 expensive batteries on board. Assessed the likelihood of being able to fit the cab cover for the night but the wind was now gusting to 47mph and Bob the Dog has no opposable thumbs and is lousy on ladders so gave it up as a non-starter. The Bad was that we heard the Rally had been closed all day Saturday after the not inconsequential craft tent had blown away so glad I had not ended up flying through the air, gripping the cab cover and screaming "We're not in Kansas anymore". Slept badly and got up a couple of times to take a look but nothing to report except that the pigs sleep incredibly lightly. Next morning Rob turned up for a bacon sandwich and we went off to the Purbeck Rally. It's a little local gem. Then came the Ugly. When it came to the commercials entering the show ring I was tooling around giving it large on the fire truck horn and a worrying vibration manifested itself. It only happened on right hand turns so after our 5 minutes of semi-rural fame we climbed under the truck to discover this. One of the left side engine or gearbox mounts has either slipped or collapsed Got back home slowly just in case and unloaded the Healey. Went back under the truck to see if the removal of a ton helped and nada. The clutch bellhousing is still touching the diff pumpkin. I can't drive like this to the Gathering so that's another missed. Have a good time chaps and chappesses.
Aug 13, 2019 21:33:34 GMT
Nooooooooooo!!
Frankenhealey
Aug 13, 2019 21:34:36 GMT
Nooooooooooo!! Yesssssssssssss
bstardchild
Club RR Member Number: 71
Aug 13, 2019 21:40:40 GMT
So come in the healey
samta22
Stuck in once more...
Club RR Member Number: 32
Aug 13, 2019 21:40:48 GMT
Anyone would think there's a saboteur in the ranks given the weekender as well. Can't be the pigs as too new, surely not Bob the dog...
Third time lucky at the NEC perhaps 🤞
Aug 13, 2019 21:49:46 GMT
Bad news, not fixable in time?
Frankenhealey
So come in the healey Your gin is safe but I've just tweaked the Healey cooling system and rejetted the carb. The results look promising but not for a first 320 mile round trip. PM me you address and I'll send you a little present.
Frankenhealey
Anyone would think there's a saboteur in the ranks given the weekender as well. Can't be the pigs as too new, surely not Bob the dog... Third time lucky at the NEC perhaps 🤞 I have effected a little sponsorship and the company that gets her through the MOT will deliver her to the NEC. They do regular unloaded runs to Birmingham so a little fuel money from me and job's a good 'un. From the car park I think I can drive the 800 yards into the halls. Afterwards we'll drive her the 180 miles home without a care as I have breakdown insurance. That insurance only gets you to a local big truck company to see if they can effect a fix. If not, it's a lowloader back home at £7.50 (ish) per mile. This is why I'm so paranoid.
Frankenhealey
Bad news, not fixable in time? It'll be a two-hander and Dangerous is off for a week so we've got Saturday 24th penned in. Need hard standing for the BIG jacks so I'll move her up to the Volcano Lair and we'll assess what needs doing. If the mounts are OK but have just slipped then we'll weld the bastards to the chassis/gearbox adapter plates. She's bolted up at the moment so that is most likely the problem. We left her like that to allow some future jiggling but it's just made my mind up to bag the front as well. That way we'll have lows for motorway and highs for other roads and off-road.
bstardchild
Aug 14, 2019 11:55:17 GMT
So come in the healey Your gin is safe but I've just tweaked the Healey cooling system and rejetted the carb. The results look promising but not for a first 320 mile round trip. PM me you address and I'll send you a little present. You are gonna hand deliver it? That’s very good of you - nearly as far as Shelsley and I’m away for the weekend - there is a show going on
Frankenhealey
Aug 15, 2019 13:01:59 GMT
I like old bags, me *Ducks as the affectionate slap round the back of the head from SWMBO fails to materialise*
bstardchild
Aug 15, 2019 15:35:49 GMT
I fail to understand why you would want air bag engine mounts but if that's solution who am I to question it........
Frankenhealey
Aug 15, 2019 15:47:29 GMT
I fail to understand why you would want air bag engine mounts but if that's solution who am I to question it........ No no no no NO! They're going to be bladderly big 'helper springs' raising the engine/gearbox relative to the axle so for less than optimum surfaces it can wallow around like a great red whale but for croozin' on de motoways we can drop her down to maximise her aerodynamics (I can't believe I've just written that!). Anyhoo it will stop/seriously reduce the banging/crashing noises that promise a wallet-emptying experience. Means I can hold my head high in the paddock with the bagged set and show them my lowz (It's all relative as Einstein said)
Aug 15, 2019 18:30:30 GMT
Aw.
I was expecting you to park up and it drop sump. That'll be the new craze, mark my words. Park up and lower your engine to the floor
Aug 15, 2019 18:52:45 GMT
Is that like the "yoots" round here that don't lower their suspension, but simply recline the seat so much they can't see over the dashboard and it makes them think they're lowered?
Aug 15, 2019 21:19:01 GMT
the only thing which parts more air than red goddess at full height, is thanos clicking his fingers.
Aw. I was expecting you to park up and it drop sump. That'll be the new craze, mark my words. Park up and lower your engine to the floor He tried that but it catches on the diff ...
So, had a mount given way, or is it just the springs settling and the clearance disappearing?
